Fuel gauge dies/drops to nothing Xantia hdi
ashy90
Bought a Xantia 2.0 HDI with a dodgy fuel gauge.
When I first got in it, the needle was right at the bottom with the light on, after driving for 10 minutes it went up to half way. I put just under £20 of diesel in anyway, which moved the needle a bit above half (below 3/4).
It took its time over the miles barely moving from just above half to just below half. However it then on the motorway suddenly started to drop to around 1/4, and then carried on right to the botyom. So from just under half to nothing in about 15 minutes or so. I put £20 of diesel in and it still remains reading nothing.
Can anyone help/advise as it definitely needs sorting
- x 6946
Re: Fuel gauge dies/drops to nothing Xantia hdi
You'll need to pop your VIN up here so we can see what exactly you have. I suspect the sender unit has got stuck or the contact wire has come away giving intermediate readings...
ashy90
Edited;
- x 5674
Your VIN will be in a cutout on the lower nearside of the windscreen, probably stamped into the offside channel at the top of the wing when the bonnet is opened and on your V5.
ashy90
Huskyxantia
- x 924
Had a car years ago same issue mine was bad contacts as well as a hole in the float.
Hope it gets sorted.
Husky.
- x 6946
Ok, so sorry for the delay - BT have cut the fibre links in the village - so been offline for a day or so...
So to confirm you have an in tank pump and gauge unit.
Here's a close up - made by Bosch. About £100 new from the link below Part number: 1607401780. Citroen charge £388 inc. VAT for this part.
https://www.ebay.co.uk/itm/Fuel-Pump-In ... 2414308036
admiral51
- (Donor 2026)
- x 391
I had to get a new pump/sender for my Xantia a few months back, got it from Here
Think i paid £60 for it delivered
Chris570
- x 36
Just as another thought here,
My Activa did the same and it was the dash pod.
Remember that the signal is electrically "softened" (for want of a better term). So if the sender goes from giving a full reading to nothing it will take the needle a long time to register that change. I couldn't be bothered with the hassle of finding exactly where the fault in the dash pod was on mine but I suspect a dry joint
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
harryp
- x 73
Certainly pays to shop around... now £50... I see
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
ashy90
GiveMeABreak wrote: 04 Jul 2019, 13:55 Ok, so sorry for the delay - BT have cut the fibre links in the village - so been offline for a day or so...![]()
Thanks for the information, very helpful. I'll check the part number to cpnform.
Do you think the cheaper fuel pumps will be ok? I know Bosch are probably the best, but I want to avoid spending £100 on the pump alone as the car needs a few other things doing
- x 6946
At the end of the day you get what you pay for - the Bosch one is a lot cheaper than the Citroen one and is of course Bosch quality. I wouldn't fit cheap parts on my car as a rule as it'a a false economy, but that;s a decision for you and available budget.
Have a look here - this is for a sender only unit (without pump), but it will give you an idea of what I'm talking about - where it can get stuck if the metal contact wire has come away or broken. It may be worth a look at yours to see if you can see if there's a similar fault before buying a new one:
viewtopic.php?f=53&t=62630&hilit=sender#p609032
ashy90
Chris570 wrote: 08 Jul 2019, 11:15 Just as another thought here,
Is your activa a S1 model Chris?
I believe the S1 has a separate circuit board on the back of the instrument cluster which can cause issues with the gauge, where as the S2 doesn't?
Chris570
- x 36
Mine is an s1 yeah. Didn't know it had a different board but my point is dont just look at one end of the circuit
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
ashy90
So with the help of a friendly garage I work next to and have got to know, we diagnosed the fault as the sender unit. This was fairly simple and conclusive with the help of a multi meter. When the fault was occurring (the gauge reading nothing) we checked the resistance at the sender unit. It was stuck at a figure (350 I believe, which is high?) and wouldn't change at all when the car was rocked (it should as the fuel moves about). The next day the gauge was working, so we re-checked the resistance of the sender and it was a totally different figure (160ish I think) and changed as we rocked the car.
So I fitted a new fuel pump ~ PWM branded one. This fixed the problem, sort of. The gauge started working, and remained working 100% of the time. With the old pump the gauge would die and read nothing on a daily basis and it would be working one minute and not the next. The new pump solved this issue.
HOWEVER, it wasn't quite right. While the gauge did drop slowly over time, it seemed to be over reading/reading high. The gauge showed about 1/3 full after driving over 500 miles. I filled up and it took 57.5 litres to fill up (65 litre tank) so it had only had approx 7.5 litres of fuel in the tank when it was showing 1/3 full.
Today I have removed the new PWM pump (temporarily fitted the original) and I have exchanged it and paid the extra for a new Bosch pump ~yet to be fitted.
One thing I have noticed is that the float on both the new pumps points the other way to the original in the car. Is this ok?
The part number (I think...theres two numbers on it) on the new Bosch pump I have is; 0580303025
is this right do you think? Euro car parts have two listed for both PWM and Bosch.
