Hi there.
Can anybody please adsvise me to the speaker and power wiring colours inc tweeters for a 2007 1.6hdi desire?
I have found loads online wilt plenty of contradicting diagrams. Is there a definitave guide.
Any info would be greatly appreciated..
Thanks in advance.
Mainly the speaker polarity colours tbf..
Xsara picasso audio wiring
- x 3298
Re: Xsara picasso audio wiring
If you could post up the VIN (which will, for security reasons, automatically be obscured so that only Moderators can read it) a Moderator could look up your vehicle and find out exactly what she had when she rolled out of the factory.
thebrasso
Cheees will do soon
Thx
Thx
- x 6948
They don't always follow exact colours, but I'll look up the diagram when I have your VIN, which I will need.thebrasso wrote: 21 May 2019, 18:16 Hi there.
Thanks in advance.
thebrasso
Chees Marc
Will be later tonight.. ok to PM you a photo of my M.O.T ?
- x 6948
Of course, but if you type it here it will be hidden automatically from public view as a safeguard, so there are no worries there. But up to you.
thebrasso
Hi Marc, my VIN is VF7**************[VIN obfuscated, can be read by forum staff] 2007 Xsarsa Picasso 1.6hdi Desire.
Hope this helps
Hope this helps
- x 6948
Ok, I have that - there's a few settings we need to tweak after the recent updates before I can upload it for you, so hopefully won't be too long.
- x 6948
8410: Audio Unit
8420: Driver's front door speaker
8425: Passenger front door speaker
8430: Left hand rear speaker
8435: Right hand rear speaker
8440: Front left tweeter speaker
8445: Front right tweeter speaker
If you want other component codes and the wiring colour codes, see the relevant section here on the Wiki:
https://www.frenchcarforum.co.uk/wiki/I ... n_of_Codes
- x 1497
Note that if you fit an aftermarket head unit, the dash display for the radio and time/date will stop working (and you won't be able to change the time/date). You will need to run in a separate ignition switched power supply, as the OE radio is switched by the BSI, and if you just connect it up, then it won't switch off at key off, or other odd behaviour may occur.
thebrasso
Thats excellent. I have had an aftermarket set up for years, but want to make sure everything speaker wise is wired correctly. (POLARITY)
Much Love
Much Love
Fullrotation
Thank you RichardW you have answered a question I have recently posted (2024) My aftermarket head unit does not switch off when key removed, it's strange you have to run a separate feed from ignitionRichardW wrote: 22 May 2019, 15:27 Note that if you fit an aftermarket head unit, the dash display for the radio and time/date will stop working (and you won't be able to change the time/date). You will need to run in a separate ignition switched power supply, as the OE radio is switched by the BSI, and if you just connect it up, then it won't switch off at key off, or other odd behaviour may occur.
