Xsara picasso audio wiring
thebrasso
Unread post by thebrasso »
Hi there.
Can anybody please adsvise me to the speaker and power wiring colours inc tweeters for a 2007 1.6hdi desire?
I have found loads online wilt plenty of contradicting diagrams. Is there a definitave guide.
Any info would be greatly appreciated..
Thanks in advance.
Mainly the speaker polarity colours tbf..
x 3302
Re: Xsara picasso audio wiring
If you could post up the VIN (which will, for security reasons, automatically be obscured so that only Moderators can read it) a Moderator could look up your vehicle and find out exactly what she had when she rolled out of the factory.
thebrasso
Cheees will do soon
Thx
x 6955
thebrasso wrote: 21 May 2019, 18:16 Hi there.
Thanks in advance.
They don't always follow exact colours, but I'll look up the diagram when I have your VIN, which I will need.
thebrasso
Chees Marc
Will be later tonight.. ok to PM you a photo of my M.O.T ?
x 6955
Of course, but if you type it here it will be hidden automatically from public view as a safeguard, so there are no worries there. But up to you.
thebrasso
Hi Marc, my VIN is VF7**************[VIN obfuscated, can be read by forum staff] 2007 Xsarsa Picasso 1.6hdi Desire.
Hope this helps :)
x 6955
Ok, I have that - there's a few settings we need to tweak after the recent updates before I can upload it for you, so hopefully won't be too long.
thebrasso
Np Thx
x 6955
8410: Audio Unit
8420: Driver's front door speaker
8425: Passenger front door speaker
8430: Left hand rear speaker
8435: Right hand rear speaker
8440: Front left tweeter speaker
8445: Front right tweeter speaker
If you want other component codes and the wiring colour codes, see the relevant section here on the Wiki:
https://www.frenchcarforum.co.uk/wiki/I ... n_of_Codes
x 1484
Note that if you fit an aftermarket head unit, the dash display for the radio and time/date will stop working (and you won't be able to change the time/date). You will need to run in a separate ignition switched power supply, as the OE radio is switched by the BSI, and if you just connect it up, then it won't switch off at key off, or other odd behaviour may occur.
thebrasso
Thats excellent. I have had an aftermarket set up for years, but want to make sure everything speaker wise is wired correctly. (POLARITY)
Much Love
Fullrotation
Unread post by Fullrotation »
RichardW wrote: 22 May 2019, 15:27 Note that if you fit an aftermarket head unit, the dash display for the radio and time/date will stop working (and you won't be able to change the time/date). You will need to run in a separate ignition switched power supply, as the OE radio is switched by the BSI, and if you just connect it up, then it won't switch off at key off, or other odd behaviour may occur.
Thank you RichardW you have answered a question I have recently posted (2024) My aftermarket head unit does not switch off when key removed, it's strange you have to run a separate feed from ignition
