So I changed the oil on the C5 3.0 hdi 2 months ago, car manual says oil capacity with filter change is 6.25L
I did everything according to the manual, put into the new oil 6.25L (supposing a mistake had been made it wasn't over 6.3L anyway!) and the stick level was slightly over the max level, the initial system oil check says "oil level correct " so I didn't empty it because it was just 3/4 mm over the max level and the system oil check said it was correct.
Now I'm getting worried and I don't know if the following 2 issues are related...yesterday while driving the car at costant speed around 90km/h the car for about 3 seconds lost rpm, like the engine was coughing. Today I start the car and the initial oil check say "oil level measurement invalid" which means, according to the car manual, the oil level indicator fault. I check the oil with the stick and it was 3/4 mm over the max level like it was when I changed it, I run the car and at 80/90 km/h it did briefly that rpm loss/coughing engine like it did before, I stop and check the oil level again and it's the same 3/4 mm over max.
Now the system oil check says the oil level is correct. Car is/was parked always straight when measuring and I waited 10/15 minutes before checking.
Dear fellows can you help find out:
A- what's the real oil capacity of the 3.0 V6 hdi engine
B- if the rpm/engine coughing episodes are related to the oil being 3/4 mm over the max
C- why the initial oil check always said it was correct except the day the engine lost briefly rpms (was the oil level indicator faulty all the way even though it says "oil level correct")
D- has the engine or any other part been possibly even slightly damaged for 3/4 mm of oil over the max?
I feel so dumb! Thanks!
C5 3.0 V6 240 hdi Oil Capacity/Over the Max Level - Did I f**k up?
tredy
moizeau
- x 429
Re: C5 3.0 V6 240 hdi Oil Capacity/Over the Max Level - Did I f**k up?
Oil capacity and how much you put in are two different things. Capacity if referring to a dry engine, after an oil change some oil remains, so you need slightly less. I always put 2/3 quantity back in, run the engine for a couple of minutes, leave to settle then fill as per the dipstick readings. I'd drain or better still suck a little oil out to remove this possibility, though without knowing how much 3/4mm is in quantity it's hard to say but I doubt that it would cause an error. Next I would have a Lexia session done. There should be a code in there unless it's cleaned itself once normal parameters were met.The auto oil check gives you an 'idea' of the oil level and alerts you if it's low, always use the dipstick for accuracy.
Pete
- x 6956
Engine oil capacity for the 3.0 HDi X7 is:
Always check oil regularly using the manual dipstick.
| Designation | By gravity | By suction |
| Oil capacity without replacement of the filter cartridge | 6,1 litres | 6,35 litres |
| Oil capacity with replacement of the filter cartridge | 6,25 litres | 6,5 litres |
| Capacity between minimum and maximum on the oil gauge | 1,75 litr |
Jay-Bruce
- x 280
3-4mm over the max doesn't sound that bad, but drain some out just in case. I doubt the slightly too much oil will have done much if any lasting damage. As for it being a possible cause of the coughing, maybes... I've dealt with lots of enigines over the years, most find their own level by evaporating off any excess, it gets splashed onto the sides of the block and underside of the pistons and the heat turns this excess oil into vapour and it usually isn't big deal. However, if the v6 3.0hdi ingests its own crank case vapour as part of the intake air, some of that oil mist might be interfering with the airlow meter or some other sensor in the intake air tract? The oil vapour would only leave a fine film of oil on the sensors if it is the issue, and can easily be cleaned off with brake cleaner / electrical contact cleaner or some such.
Put a fault code reader on your car and see what codes it flashes up? Even if you don't have one yet, a cheap bluetooth ebay special with a suitable app such as Torque on your phone will let you see basic engine codes on these cars. The faultcodes, if any are logged, will point you in the right direction to sort out the fault, if they don't try cleaning the air flow meter and intake air temperature and Manifold Absolute Pressure sensors.
I suspect however, that you probably did a fuel filter at the same time, and I wonder if the coughing it the car getting a little bit of air in the fuel system? If so it will probably work itself out in time. Also, if doing the oil and filter change, did you do the air filter? Could there be something not sealed up correct allowing some "unmetered air" in to the engine?
Don't beat yourself up about it, you haven't wrecked your car, whatever is causing the intermittent coughing won't be anything major and we will help you get to the bottom of it. If you are anywhere near me (north aberdeenshire) I could easily plug in a lexia/diagbox laptop and see what your car has to say for itself?
Jay-Bruce
- x 280
AH! Just noticed the OP is in italy
If he wants to pay my flights I'll easily come over with my diagnostics laptop for a working holiday, drinking wine, and playing with citroens in the sun sounds great
tredy
update: oil level increased because dpf was regenerating, so diesel was injected into the oil, the very brief coughing of the engine was probably related to this, it hasn't done it again, now oil level is 3/4 mm below max and I'll probably keep it at this level.
@jay-bruce thanks but hey I wish it was sunny!! we're having a true scottish weather this may!
Jay-Bruce
- x 280
Glad you got the citroen sorted, but even if the weather was scottish rather than sunny, I'd still have relished the trip for access to real italian food
There is nothing in the world, up to and including the outbreak of a full on nuclear war, that cannot be sorted by good lasagne and tiramisu.
