Xantia II Leakage
Citro83
Xantia II Leakage
Unread post by Citro83 »
Good afternoon to everyone,
I decided to check my car today and I randomly observed the following issue. I saw the leakage of the video.
Here is the link of the video
What is this liquid? Is this a serious problem? What is the name of that spare?
Thanks in advance!!
Reason: Video link
furriegurrie
x 40
Re: Xantia II Leakage
Unread post by furriegurrie »
That would seem to be a serious issue indeed. I'm not familiar with this engine so can't help on the part. You'll have to try and find out what the fluid is. I suspect water from the cooling system, but it could also be petrol perhaps. Easy to figure out by smell. Good luck!
x 1751
Agreed - you should be able to tell from the spilled liquid: choice of water/coolant, petrol, or LHM.
Should be straightforward to identify.
Looks like a major leak, so car should definitely not be driven.
:!: If petrol, a risk of a serious fire.
Timmo
(Donor 2022)
x 168
Unread post by Timmo »
Is that not the fuel pressure regulator? I'd suggest that's petrol Pouring out of it! Looks like the supply and return lines, I am not familiar with the engine, only going on its predecessor in the gti and mi16, you should be able to tell from the smell, looks far too clear for lhm or coolant.
'58 C2 Code
'58 partner teepee outdoor
x 5670
If petrol surely the smell would give it away immediately?
A match would confirm :twisted:
Otherwise a small sample smell/taste tested?
Citro83
Unfortunately, the liquid is petrol. Also, the two pipes are the fuel supply & return lines. I changed the clips from the pipes and the leakage reduced. In fact, I though that the problem was vanished when I started my car. But, some hours later I made the same inspection and observed a tiny leak again. Something like 1 drop every 5 seconds. I have scheduled an appointment with my car mechanic for tomorrow.
x 1751
Glad you got that leak identified - it could have been the cause of a serious incident.
Hopefully some replacement pipework will be a permanent cure.
Mandrake
x 695
Unread post by Mandrake »
Had that happen on my old Xantia 2.0i petrol - petrol squirting from the hose at the end of the fuel rail. Luckily I spotted it under the bonnet before it became a fire! :shock:
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
oscar
x 8
Unread post by oscar »
Funny enough? The worse ones are Brake fluid! more cars have caught fire from that leaking than most other things also concentrated anti freeze is another
Petrol esp when hot evaporates quickly it's a spark that is the bug bear with it but heat sets the others off
x 3302
LHM has the genuinely nice property of non combustion. I remember seeing a video where a fire officer (using a beaker at the end of a long pole) pouring brake fluid onto a (demonstration) engine bay fire. The fire got more vigorous. Then the same test was done, but using LHM. The fire went out.
