Edc15c2 pinout
taffy
Edc15c2 pinout
Unread post by taffy »
Hi does anyone have a pinout for edc15c2 its a 3 plug off a 2.2 hdi
Many thanks
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
taffy
Re: Edc15c2 pinout
Heres what lexia suggests for fuel pressure signal fault
x 6957
Re: Edc15c2 pinout
Ok, here you go:
This is the 3 Pin High Pressure Diesel sensor connection to the Engine ECU as described - which should be a 3 pin yellow connector, then under that is the 20 MOT harness it runs through and finally, the location of the 20 MOT harness for you:
taffy
Re: Edc15c2 pinout
OK I'm trying work it out lol are h g and f locations on the ecu?
x 6957
Re: Edc15c2 pinout
Those are generally marked on the plug casings or inside. They serve as an identifier.
