Hi does anyone have a pinout for edc15c2 its a 3 plug off a 2.2 hdi
Many thanks
Edc15c2 pinout
taffy
Edc15c2 pinout
06 silver 1.6 hdi vtr c5
08 black C4 GP 2.0hdi vtr
taffy
Re: Edc15c2 pinout
Heres what lexia suggests for fuel pressure signal fault
- x 6956
Re: Edc15c2 pinout
Ok, here you go:
This is the 3 Pin High Pressure Diesel sensor connection to the Engine ECU as described - which should be a 3 pin yellow connector, then under that is the 20 MOT harness it runs through and finally, the location of the 20 MOT harness for you:
taffy
Re: Edc15c2 pinout
OK I'm trying work it out lol are h g and f locations on the ecu?
- x 6956
Re: Edc15c2 pinout
Those are generally marked on the plug casings or inside. They serve as an identifier.
