Year 2099?
Xantippa
- x 29
Year 2099?
What might be wrong, my gps is showing year 2099 and altitude -20m today?
Onlinemyglaren
- x 5630
Re: Year 2099?
It is the Y2K syndrome again
Explanation and possible remedy here
Must go and dig mine out and see how it has fared.
- x 1751
Onlinemyglaren
- x 5630
Re: Year 2099?
Not to forget the impact of B*****
Onlinemyglaren
- x 5630
Re: Year 2099?
Remembered to try my satnav today - it is rarely used.
Won't even boot up
Won't even boot up
- x 1908
Re: Year 2099?
It might be sulking from lack of use. How long since you last ran it?
Onlinemyglaren
- x 5630
Re: Year 2099?
Probably last year sometime. I do drag it out and charge it periodically although it rarely needs it.
A good excuse to replace it - no updates in it's lifetime so it is often of limited use.
Xantippa
- x 29
Re: Year 2099?
Is there anything to fix this problem other than set clock and date manually? I guess this would require software update, and that won´t happen anymore.
Onlinemyglaren
- x 5630
Re: Year 2099?
Mine has resurrected itself.
Did some pootling around with just the map showing and it got the positioning correct.
Set it to take me home (only half a mile in a straight line but three miles by road)
It knew the way and I confused it by taking alternative routes, recalculated correctly within a few seconds.
Time was correct too, never looked at the date.
- x 2943
Re: Year 2099?
Lots of chat here about this, other makes sites have similar discussions.
https://discussions.tomtom.com/en/discu ... l-over/p1
Sloppysod
- x 382
Re: Year 2099?
myglaren wrote: 12 Apr 2019, 21:58 ........ Set it to take me home (only half a mile in a straight line but three miles by road)
It knew the way and I confused it by taking alternative routes, recalculated correctly within a few seconds.....
Yes, but it knew where is was going, even I know where home is without thinking....too much
Stu
Onlinemyglaren
- x 5630
Re: Year 2099?
At least it knows where home is.
Will be going to Teesside next weekend so will see if it can find it's way there.
It knew when I was at my son's house - ¼ mile away (1 mile to drive there).
It hasn't been there before
