2000 Dispatch: Battery light flickering very dim, terminals at 14.3V, alternator replaced 2 weeks ago.
kenbw2
(Donor 2017)
x 24
Unread post by kenbw2 »
Just done a service - including a new fan belt.
Started it up and noticed the battery light is on very dim. While driving it flickers between dim and off, notably when decelerating it goes off entirely
I tried disconnecting the battery with the engine running, light still on dim.
It's definitely charging - the voltage at the terminals is 14.3V
Edit: Notably I had a dead alternator on it 2 weeks ago, which I replaced with a second hand one which worked fine till now.
x 1240
Re: 2000 Dispatch: Battery light flickering very dim but terminals at 14.3V
Unread post by Peter.N. »
Do you notice any variation in the brightness of the panel or interior lights? If not could be an alternator fault or a poor electrical connection somewhere. Personally if its still charging OK I wouldn't worry about it, just check the battery voltage periodically. Check the thin wire connection on the alternator.
Nemo26
x 4
Unread post by Nemo26 »
Google ac ripple test. You have too much ac current in system. Diode failure probably.
kenbw2
(Donor 2017)
x 24
I hope not, I've just replaced the alternator 2 weeks ago - admittedly with a second hand one, but still.
Does this point to an issue somewhere in my electrical system?
x 1751
Don't run the engine with the battery disconnected. Risk of damage to both alternator and other electronic items, due to alternator not being able to read a battery voltage.
kenbw2
(Donor 2017)
x 24
Re: 2000 Dispatch: Battery light flickering very dim, terminals at 14.3V, alternator replaced 2 weeks ago.
Hmm I do have a dicky positive terminal connection. Maybe that's destroying alternators?
