Hi There.
I'm doing a little investigation into the location of the following sensors, due to an electrical issue with my car, and would really appreciate if anybody could advise me to the location if the following sensors.
Inlet air Pressure sensor
Fuel rail pressure sensor
Turbocharger copy position sensor
Air conditioning pressuere sensor
Any help as ever would be greatly appreciated.
Xsara Picasso 1.6hdi (2017)sensor locations
- x 6957
Re: Xsara Picasso 1.6hdi (2017)sensor locations
No3: Water Temp. Sensor No 6: Engine Speed Snesor No 7: Camshaft Position Sensor No 8: Temp. Sensor (Go + Support) No 9: Intake Air Pressure Sensor No 11: Air Intake Temp. Sensor No 12: Diesel High Pressure Sensor (Rail) |
- x 1486
There isn't one.... if it's a 110 engine, there is a feedback sensor built into the vacuum control solenoid down the back of the engine, but nothing on the turbo itself.
- x 6957
It’s a DV6ATED 92 BHP Richard
thebrasso
Excellent work.Thank you!!
- x 1486
It does appear to have the turbo solenoid down the back of the engine as well - there is something different about the turbo though IIRC - I think perhaps it's wastegate controlled rather than VVT as the one on the 110 is.
thebrasso
GiveMeABreak wrote: 27 Mar 2019, 11:37The turbo copy position sensor is not shown separately.
Sensors.PNG No3: Water Temp. Sensor
Hi Marc, Where can i get theses diagram from?
