Mk1 Xantia window relay
kiwifrog
Unread post by kiwifrog »
The drivers side (right) window will go down ok but the relay inside the door just clicks when trying to go up, I have to pull the glass at the same time operating the switch to get it to come up, is it the relay thats playing up something in the mechanism ?
x 1473
Re: Mk1 Xantia window relay
Unread post by xantia_v6 »
I don't think that there is a relay in the door. Have you seen one? Maybe you are hearing the gears click as the motor struggles with a jammed window.
kiwifrog
xantia_v6 wrote: 24 Mar 2019, 09:55 I don't think that there is a relay in the door. Have you seen one? Maybe you are hearing the gears click as the motor struggles with a jammed window.
yes I took the door panel off and there is a box with a relay for both left and right switches
x 1473
kiwifrog wrote: 24 Mar 2019, 17:57
That seems unusual, as the window switches are 3-position switches, so you cant control the motor with just a single relay.
Does your car have a one-touch drivers window? Can you post a picture of the relay box?
x 1746
If one-touch operation, there is a likely a current-limiting (and maybe auto-backoff/anti-pinch) facility, so if the window movement is stiff, you'll just hear a click/clonk and no movement. Give the felt channels a good squirt of WD40 or silicone spray, and grip the glass (one hand each side, for safety) to encourage it up.
kiwifrog
Yes it's the one touch on the drivers side
x 1473
Here are the front window wiring diagrams that should be applicable to your mk1 Xantia (with one touch drivers window):
I think however that your problem is more likely to be mechanical than electrical. The anti-pinch function will stop the window from rising if it is having to apply too much force.
kiwifrog
Ok Thanks, I will get some silicon spray and see if that helps
x 3296
I had this problem with my previous C5 (and Mum did with her Volvo), and a proper (3 in 1) silicone lubricate sorted the problem out for a year or so, when it then needed another application.
x 1746
Same on XM here.
van ordinaire
(Donor 2017)
x 400
1st time I opened the f. pssenger window on my Xantia & tried to close it, it went up about 4" & dropped back, several times. Eventually gave up & thought I'd wait 'til I got back to the house (this was collecting it from the vendor). Some time later, perhaps stuck in traffic, I idly hit the switch & the window closed; not dared open it since!
Oh, & it doesn't matter which switch I used.
Any ideas?
Sorry to have butted in.
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
x 3296
That sounds like the anti pinch control kicking in. If the system 'thinks' there is something in the way (such as a child's head) it will (because of the extra resistance) back away. This can (and almost certainly is, in your case) be caused by dirt built up on the guides restricting the movement of the window. Silicone spray (I have used 3 in 1 silicone lubricant spray) in the guides can help overcome this for a while (in my experience it worked for a year before I needed to apply it again).
x 1473
I am not aware that a mk1 Xantia was ever fitted with one-touch or anti-pinch on the passengers window. Maybe someone has upgraded it?
I think that someone sent you the spec sheet for your car which should tell you.
x 1746
Issue confirmed as relating to driver's side, one-touch, so I guess anti-pinch almost certainly fitted, Mike.
x 1473
white exec wrote: 25 Mar 2019, 23:37 Issue confirmed as relating to driver's side, one-touch, so I guess anti-pinch almost certainly fitted, Mike.
I was responding to James who was I think responding to Van who was reporting an issue with the passenger side window.
