CD changer
This section is for information and posts relating to Audio Head Units, and Navigation Systems
C4robot
CD changer
Unread post by C4robot »
Hi ,
Have recently bought a 2006 C3 decided to buy an original Blaupunt CD changer to put in place of the centre cubby and stupid me expected it to plug in and play 😂 seems that the CD changer option has to be activated in Lexia is a RD4 head unit, anyone know of anywhere that can activate this other than main dealer in Newcastle upon Tyne area? Thanks in advance 😁
x 6945
Re: CD changer
Before you get too carried away about activating it, did you also check you have the correct CD Changer? These have to be compatible with the car's architecture. Bosch made the ones for the C3 II. What is your VIN and I'll check.
C4robot
Re: CD changer
Oh 🤪 I did not know that 😂 the vin is VF7**************[VIN obfuscated, can be read by forum staff] Thanks
x 6945
Re: CD changer
Ok, so your C3 has full CAN multiplexing so these were the Blaupunkt units - so hopefully you'll be good to go. :-D
The PSA part number is: 6564RK
But they also did a reconditioned unit using this part number: 16074886XT.
So searching on ebay or elsewhere on these numbers should confirm you have the right one.
C4robot
Re: CD changer
car been in storage so first chance I've had to have a look, this is the label that's on the side 🙄
x 6945
Re: CD changer
Do you have the label on top?
C4robot
Re: CD changer
Unfortunately not, just plain metal on top🙈
x 6945
Re: CD changer
So here's a compatible unit for £25 (collection in Upminster) - but you may be able to contact the seller to arrange an additional PayPal payment if you can convince him to post it for you possibly?
This one will obviously have a different serial number stamped into the unit, but is the same unit.
https://www.ebay.co.uk/itm/PEUGEOT-307- ... Swol5YvrLL
