Just installed diabox on laptop, first time using diagbox and lexia. I've not hooked it up to the car yet but looking within DiagBox / PP2000 there are three different models for the 207 -
207 VAN
207 CAN
207i
Does anyone know what models / year of 207 these refer to ??
I have a 207 sport SW, 1.6hdi 90hp (Oct 2009
207 diabox enquiry
fotobright
207 diabox enquiry
Peugoet 308 SW HDI 1.6 Live*
Peugoet 207 SW Hdi 1.6
C5 2.2L HDi 16v estate (01)
Xsara Hdi 90 estate
Xantia 1.9TD estate, (veg oil)
Zx 1.9TD hatchback
Zx 1.9D hatchback
Xsara Hdi 90 estate
Zx 1.9TD hatchback
Zx 1.9D hatchback
- x 6945
Re: 207 diabox enquiry
Diagbox will launch the correct software for the vehicle and being a 2009, that will be Diagbox.
No need to worry about the electronic architecture, as Diagbox will determine this once it has connected and correctly identified the VIN.
If you have not used the software before, I strongly suggest you read the guidance here first:
Diagbox User Advice
If you want to know what the electronic architecture your 207 uses, you will need to pop up your VIN here.
Diagbox User Advice
MikeT
- x 232
All I know is I initially chose the wrong 207 (petrol) model once and was met with a Global Test list of ECU's not found. After backing out and the correct model selected, I could interrogate all the systems just fine.
fotobright
GiveMeABreak wrote: 15 Jan 2019, 14:01 Diagbox will launch the correct software for the vehicle and being a 2009, that will be Diagbox.
Diagbox User Advice
Thanks, will defo read the diagbox advice first.
Xsara Hdi 90 estate
Zx 1.9TD hatchback
Zx 1.9D hatchback
Xsara Hdi 90 estate
Zx 1.9TD hatchback
Zx 1.9D hatchback
fotobright
MikeT wrote: 15 Jan 2019, 15:06 All I know is I initially chose the wrong 207 (petrol) model once and was met with a Global Test list of ECU's not found. After backing out and the correct model selected, I could interrogate all the systems just fine.
Good to know, thanks
Xsara Hdi 90 estate
Zx 1.9TD hatchback
Zx 1.9D hatchback
Xsara Hdi 90 estate
Zx 1.9TD hatchback
Zx 1.9D hatchback
