Hi guys.
Well. I have been busy cleaning my C5. Took off the front and cleaned as much as I can. Even partially dismantled radiator to get the trash out between the radiator and the condensor.
The Engine sump was leaking too. Resealed it although I am having my doubts....
Anyway. After further inspection I saw passanger side driveshaft outer boot is torn, sigh.
I did an ebay search but there are too many variants. How can I figure out which one I have to use? I have a 2001 c5 3.0 v6 exclusive auto.
Thanks in advance
Corne
2001 c5 driveshaft boot
- x 1240
Re: 2001 c5 driveshaft boot
If you put a search into Ebay it will probably come up with loads, if you are not sure about it, cross check it with others listed, you should be able to find what you want.
cornesoutafrica
- x 9
Ok. Thanks. Will do
- x 6950
I don’t think I have your C5 VIN Corne, but there are several types for the 3.0 V6 depending on the Auto box you have and also they changed from a certain build date. Pop your VIN up if you want the part number for the boot kit.
cornesoutafrica
- x 9
Hi Marc
That is what I thought. That will clear the mountain of different types of CV boot kits.
My C5 Vin is VF7**************[VIN obfuscated, can be read by forum staff]
I'd appreciate it. possibly I can get the genuine one off ebay instead of getting an aftermarket one. I like to use OEM parts as much as possible.
Regards
Corne
Regards
Corne
- x 6950
Sorry about the delay - just been out for a New Year's Eve Tipple with friends!
- Item (4) Kit on diagram (Final Drive Dimension Side: Part No: 3287A5 £43.46 inc. VAT UK.
- Item (3) on the diagram (Wheel Side) Part No: 329334 £37.79 inc. VAT UK
cornesoutafrica
- x 9
Thanks Marc
Apologies for late reply. Got one on ebay. Oem for £20. Hope it arrives someday.
Thanks so much.
Regards
Corne
Thanks so much.
Regards
Corne
- x 6950
Previous Posts Relating to the 3.0 V6 MK II Driveshafts / Boots have been moved into a separate topic:
viewtopic.php?p=699915#p699915
