Xsara Picasso 2007 1.6hdi camshaft sensor
thebrasso
Unread post by thebrasso »
Has anybody changed their camshaft sensor.. ?
What does it entail and is it easy 2007 1.6hdi
Much love :)
Reason: Edited Title to Improve Searching
Simple76
x 9
Re: Xsara Picasso 2007 1.6hdi camshaft sensor
Unread post by Simple76 »
Believe it’s in the back off camshaft in the top cover
x 6958
thebrasso wrote: 13 Sep 2018, 19:45 Has anybody changed their camshaft sensor.. ?
Much love :)
John, pop up or PM your VIN so I can determine which variant of the DV6 engine you have.
x 6958
No matter, it's the same sensor and in the same position - number 7 in the diagram:
thebrasso
Thanks for the fast reply. It's really appreciated
thebrasso
Where can I download these images from...?
x 6958
This is just the parts diagrams from PSA. I’ve just screen shot them for you, they are not downloadable.
thebrasso
Hi. How do I actually get to the sensor,??
x 1441
I suspect it's not as easy as Haynes makes out.... :rofl2: That is going to be well buried under the scuttle, and is on the back of the engine. The Cit manual suggests putting a 9.5mm drill between the sensor and the timing belt cover, which probably removes the need to take the timing covers off (which requires removal of the engine mount IIRC....). What makes you think it needs a new sensor? It's only used at start up to check the synch of the cam and crank AFAIK....
sparksie
x 33
Unread post by sparksie »
Words right out of my mouth!
Never had to change one on a HDI, so somewhat surprised at this one!
Sparksie
2000 Xantia 1.9TurboD
