Xantia 1.9 TD 97
I've got a leaking sphere mounted on the front end of the engine itself. I'm sure it near the system depressure value but I can't work out if it the accumulator sphere or an ordinary one. The Suspension spheres have all been replaced within the last 2 years.
Does anyone know which it is please ?
My engine clicks more frequently than 45 seconds anyway so I would need to replace it anyhow.
Xantia leaking sphere
If it's the sphere mounted directly on engine block - then it's the main accumulator sphere - same type fitting all earlier generation hydraulic Citroens.
If the sphere is fitted on a chassis part as sphere no. 2 found down in engine bay - clearly not on engine - then it's the HA2 front center sphere.
