Citroen Xsara hub nut torque
dave_xsara
(Donor 2021)
x 10
Unread post by dave_xsara »
Can someone tell me the hub nut torque setting for the front hub in the 2.0HDi Xsara?
Thanks.
wurlycorner
x 271
Re: Citroen Xsara hub nut torque
Unread post by wurlycorner »
Driveshaft nut?
According to the Citroen official service manual...
32.5 m.daN
(239 ftlb)
In other words... F'in tight!
Iain
CX DTR T2 Safari (silver)
x 6945
If it's the Hub Nut (M24 x 150), then it's 32,5 ± 2,6 daNm.
Iain just pipped me on that one! :)
dave_xsara
(Donor 2021)
x 10
Yip, hub nut.
Thanks - my torque wrench doesn't go beyond 200ftlb.
wurlycorner
x 271
Just do it up to that and then give it an extra tug, that'll be fine.
Iain
x 1938
Unread post by Paul-R »
Effin tight. When I had a Xsara I would slip a 4ft gas pipe extension over the breaker bar and tighten up using that. Basically so you can't undo it without the gas pipe.
Never had one come off.
EDC5
x 130
Unread post by EDC5 »
Out of interest, what is the specified torque for the X7 front hub nut? I remember using a huge 1" socket set (normally used for tractor bolts) and did it as tight as possible.
x 6945
On our X7s, the hub nut is tightened to 34,5 ± 1,7 daN.m Elis.
EDC5
x 130
That's pretty damn tight! At least it can't come loose what with the locking pin design.
