Hi,
Can someone tell me the hub nut torque setting for the front hub in the 2.0HDi Xsara?
Thanks.
Citroen Xsara hub nut torque
wurlycorner
- x 271
Re: Citroen Xsara hub nut torque
Driveshaft nut?
According to the Citroen official service manual...
32.5 m.daN
(239 ftlb)
In other words... F'in tight!
32.5 m.daN
(239 ftlb)
Iain
CX DTR T2 Safari (silver)
Iain
- x 6945
If it's the Hub Nut (M24 x 150), then it's 32,5 ± 2,6 daNm.
Iain just pipped me on that one!
dave_xsara
- (Donor 2021)
- x 10
Yip, hub nut.
Thanks - my torque wrench doesn't go beyond 200ftlb.
wurlycorner
- x 271
Just do it up to that and then give it an extra tug, that'll be fine.
Iain
Iain
- x 1938
Effin tight. When I had a Xsara I would slip a 4ft gas pipe extension over the breaker bar and tighten up using that. Basically so you can't undo it without the gas pipe.
Never had one come off.
EDC5
- x 130
Out of interest, what is the specified torque for the X7 front hub nut? I remember using a huge 1" socket set (normally used for tractor bolts) and did it as tight as possible.
- x 6945
On our X7s, the hub nut is tightened to 34,5 ± 1,7 daN.m Elis.
EDC5
- x 130
That's pretty damn tight! At least it can't come loose what with the locking pin design.
