Hi Folks,
I'm starting to get a fairly bumpy ride in my 1997 Citroen Xantia Estate 1.9 TD (Desire), mostly on the back wheels. All the spheres were re-gassed about 10 years ago but now it looks as if they need replacing. The front spheres don't seem too bad, It's mainly the back.
I have a few questions though if someone here can help me?
Is it better to replace all the spheres at this stage or just the back ones?
Is my version of the Xantia Estate Hydractive or no?
It seems there are 6 spheres in total - (2 back, 2 front, and 2 accumulator spheres?) It seems easy enough to find front and back but when i mention the accumulator ones suppliers don't seem to know what I'm talking about (Mister auto etc) ... Are the accumulator ones different/ specialist?
Any recommended suppliers? (I am in Ireland).
Thanks in advance,
Bryan
Replacing Spheres on a 1997 Citroen Xantia Estate 1.9 TD
BMBCreative
- x 6957
Re: Replacing Spheres on a 1997 Citroen Xantia Estate 1.9 TD
Bryan - the best option first is to pop up or PM your VIN. I can then get determine what type of system you have and also the correct OEM sphere part numbers with the correct pressures etc.
You can then decide where to get them from with this information. They do vary depending on shape and engine and of course hydractive or not. I would certainly NOT rely on third party non-specialist suppliers for the correct ones without first arming yourself with what you should have. It has been shown numerous times that it is a lottery out there.
I can then get you the OEM parts and prices, that you can use for sourcing replacements according to wishes / budget. They are not all the same and quality has been shown to vary - especially with regard to the membranes used in construction.
- x 3306
May I suggest you contact AEP Direct? They know what they are on about, can supply most spheres, and (for orders over £50) they do free P&P;
http://www.aepdirect.com/
I have used them myself in the past, and was happy with the service. If you do decide to use them make sure you give them your reg number. That way they can check that the spheres you have ordered are the right ones for your car.
- x 1751
Bryan, are you sure the spheres were "regassed", and not just replaced?
If they have been regassed, each sphere would be fitted with a chromed Valprex valve (with a green plastic protection cap) screwed into their tops, instead of the factory-original blanking cap (plain round thing, about 16mm diameter).
If you do have the Valprex regassing widgets, regassing them again might be an option, if the spheres are still intact and haven't been run flat, although 10 years is pushing it by a factor of about two!
If any of the spheres are of the later grey flatter "saucer" type, they cannot be regassed, only replaced.
Do let us know VIN number, in any case.
BMBCreative
GiveMeABreak wrote: 30 Jul 2018, 15:44 Bryan - the best option first is to pop up or PM your VIN. I can then get determine what type of system you have and also the correct OEM sphere part numbers with the correct pressures etc.
HI Marc,
Many thanks for the advice and apologies on the delay in replying, I've been out sick.
Cool, The Vin number is VF7**************[VIN obfuscated, can be read by forum staff] 17E00017E5109
I don't think my version is hydractive.
BMBCreative
Hell Razor5543 wrote: 30 Jul 2018, 16:02 May I suggest you contact AEP Direct? They know what they are on about, can supply most spheres, and (for orders over £50) they do free P&P;
Do AEP ship to Ireland ?
BMBCreative
white exec wrote: 30 Jul 2018, 16:03 Bryan, are you sure the spheres were "regassed", and not just replaced?
Hi Chris,
Apologies I've been ill.
I definitely think they were regassed rather than replaced & they're all the green ones.
I want to replace them now for longevity of the membranes etc., especially the back ones as they're getting quite hard now.
- x 1751
If regassed, they will have a valve at the top, and not a round green stopper. If there's a valve there, re-gassing is an option, but if the spheres are really old (5 years+) then probably best replaced.
Hope you feeling fit again!
- x 6957
Here you go Bryan, sphere part numbers, volume and pressures.
Here's a video of a DIY replacement - just thought I'd add this in whilst I was at it!
| Sphere | Part No | Volume | Pressure |
| Front | 95666857 | 400 CM3 | 55 Bars |
| Rear | 527240 | 400 CM3 | 40 Bars |
| Anti Sink Sphere | 529303 | 400 CM3 | 50 Bars |
| Accumulator Sphere | 95666763 | 400 CM3 | 62 Bars |
BMBCreative
Hi Marc,
Thanks a mill for all that. That’s brilliant.
So do all Xantia’s (including my estate) have 6 spheres?
2 front, 2 back, an accumulator & an anti sink sphere?
Cheers,
Bryan
Cheers,
Bryan
- x 6957
Standard non-hydractive systems have 6 spheres Bryan - one each corner, an accumulator and anti sink (although the anti sink function is really done using non-return valves to keep the pressure in the spheres). Xantia Hydractive systems add another front centre and rear centre sphere. These switch in and out according to road conditions or when in sport mode. Sport mode uses just the 4 corner spheres giving a firmer ride, whilst using the additional centre spheres will give a softer ride.
The Activa with ARCS (Active Roll Control System) actually has 10 spheres - but not all these are used for suspension purposes.
BMBCreative
Great, it seems only the back is giving a hard ride. Mine is non hydra Five, Would I get away with replacing or do you think it’s better to replace all? I don’t think there is anywhere that can regas them around me at this stage.
- x 6957
If the rears have gone, then I would suggest the fronts and the other 2 would also benefit from new ones unless they have already been replaced.
- x 1751
Life of the traditional round green spheres is 3 years or so (without any re-gassing), with the anti-sink and Accumulator spheres maybe twice that, as they do less arduous work.
At 10 years, I'd really recommend replacing all of them.
Can't help with pointing up anyone near Limerick who might have re-gassing kit, but someone here just might just know, or you could talk to some independent Citroen workshops, who might have some info. Main Citroen dealers/agents tended not to get involved in re-gassing (which goes back decades), but some independents did.
