xantia bump stops c5 ones fit
c.morewood
- x 55
Having searched the web for Xantia bump stop replacements.. I be found that with a small modification, C5 bump stops will fit the Xantia. You need to cut the flat base of the stop to fit the slight v shape of the Xantia, then cross cut the nipple with a Stanley knife, grease it and use a long handled 5mm flat blade screwdriver to ease the nipple, far side first, into the hole. Hope this helps..
PS its no longer an MOT fail or advisory.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
- x 1751
Re: xantia bump stops c5 ones fit
I had to do something similar (in 2015), Chris, for our XM rear bump stops (inside the large circular cross-tube).
The original (5166.52) had crumbled, and was NFP: A C5 item (5166.66) still available, and just needed some trimming of height, top and base-angle: Final result: Other possibilities, still available then seemed to be
5166.77 (C5 & C6)
5166.37 (Saxo) h=48mm
5166.44 (Saxo) h=61mm
5166.42 (Xantia)
5166.77 (C5 & C6)
5166.42 (Xantia)
- x 6957
What a creative lot we are!
- x 1942
"We"?
- x 1751
- x 6957
I'm referring to the various innovative efforts of members both individual and collective to find ways of keeping keeping their cars on the road / and general problem solving - what's your problem?
c.morewood
- x 55
That's the v shape I was talking about.. I was a bit too severe with the cuts on mine.. but was rushed trying to get them fitted less than an hour before the MOT. I failed and needn't have worried as they're no longer part of the MOT. At least this is publicised now so others can use the information.
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- x 1942
Should've put a smiley at the end to show I was being facetious. Sorry.
- x 6957
No problem, just paying homage to the strut top solution, the welding and fabrication thread, steering rack mods, hydraulic valve mods and the like that have been discussed lately
- x 1751
Make Do And Mend, mixed with a bit of lateral thinking.
How else to proceed?
leithant
- x 9
BTW, if you have a C5 Mk 1 or 2, it pays to check your stops. Mine were missing! My towbar was hitting the road reversing out of my driveway, and tht was the cause.
06 Citroen C5 Estate 2.2 Hdi Auto
95 Peugeot 306 S16
95 Silver Xantia VSX - now deceased
95 Peugeot 306 S16
oscar
- x 8
Check people like Pro flex/power flex they make polyurethane bushes/bump stops and some are generic type
- x 1751
I've used Powerflex before (for polyurethane ARB bushes, to replace the useless 'rubber' ones on a RAV4), and found them very good. A huge range of OE replacements, as well as generic items.
oscar
- x 8
When was running a hot ford sierra it was fully poly bushed through out was like driving a dammed Kart you touched wheel and that was where you went it was so driveablewhite exec wrote: 22 Nov 2021, 06:43 I've used Powerflex before (for polyurethane ARB bushes, to replace the useless 'rubber' ones on a RAV4), and found them very good. A huge range of OE replacements, as well as generic items.
Gregor
- x 16
