steering wheel movement
- Donor 2023
Hi, my S1 Xantia 1.9 TD, the steering wheel , when braking, there is slight movement , north to south, it feels like something is loose, any help or guidance would be greatly appreciated, many thanks Terry.
- x 4930
Re: steering wheel movement
From your initial description it sounds like your discs might be warped causing the vibration when braking. How long have they been on since changing?
They can warp from the excessive heat buildup and then rapid cooling, like going through water. I go through a set of discs every 2 or 3 pad changes.
- x 26
I experienced a similar problem on a BX where the lower bearing in the steering column had slid down the shaft, it slid back up and was good.
