C5 2.0HDi antipollution fault + revs limited
russell37uk
Unread post by russell37uk »
Hi i have a 2003 C5 2.0HDi , approx 137,000 miles, and have a problem which i hope someone can shed some light on - im not very tech minded to keep the answers simple (ish)
My C5 has developed a Antipollution Fault, and the revs are limited to approx 3000rpm, which isn't too bad once up to cruising speed, its just getting to that speed.
Car does pull ok but a bit slow and lacking in power, not a big issue on the flat but its hard going uphill, have to use 2nd a lot!
A garage has taken it for a test drive and said that its not running to its full advantage, which i can see and appreciate, i just didnt notice the big loss of power as im driving daily and if the power has slowly reduced over time (a little at a time) then you tend not to notice small changes.
Anyway garage took it for said test drive, and confirmed (as i knew now) about the loss of power and i just put it down to being related to the antipollution fault, bot myself and the garage, took it for granted that it would be the EGR valve so had this replaced, however this has made NO difference - antipollution fault still present, and the loss of power.
Garage then also did a test drive with the MAF sensor? (under the air intake/filter) disconnected, but this made no difference to either issue.
Any suggestions on where to look next, and ideas on the possible costs?
I would add that the garage has offered to do a full diagnostic test at no cost due to wrongly diagnosing a EGR fault. but just want to know what costs i could be looking at.
x 6956
Re: C5 2.0HDi antipollution fault + revs limited
The engine ECU will put the car into what is often termed ‘limp mode’ when it detects issues with anything that can damage the engine or the emissions equipment.
This basically limits the power available to reduce damage, and is telling you to get it sorted basically.
Do you have your VIN code or registration so we can determine your exact model, engine type and emissions equipment fitted. You really need to get it to a garage with a Lexia 3 diagnostic and provide us with the fault codes, but in the interim, the VIN or reg will help.
russell37uk
Hi GiveMeABreak,
Thanks for your reply.
I do not have the VIN code at the moment, and would prefer not to post my Reg on a public form, so will pm you the reg if thats ok with you.
x 6956
Yes, PM it, that’s fine.
russell37uk
Sent
x 6956
Ok, so you have the C5 2.0 HDi 110 (DW10ATED) with Manual gearbox 5, and no Particle Filter.
So that's the good news, no particle filter clogging up or Eolys to refill. So what you really need now is to get some diagnostic codes as I mentioned earlier - As you've already found, replacing parts without doing this can be expensive and unnecessary. There could be issues with the air flow meter (MAF), the air or fuel supply / pump, a Turbo hose leak or one of a number of sensors. So we really need to get some fault codes from a Lexia to understand what it is not happy about and this may save you some time and money by pointing you in the right direction.
x 3304
I occasionally got an Anti Pollution fault on my C5 Mk1, and it turned out that the rubber pipe that connected onto the EGR had a pinhole leak at one end. Michel found it, nipped the pipe back by about 1cm, and the fault has not returned since. It could be worth checking the rubber pipes along the firewall bulkhead.
russell37uk
GiveMeABreak wrote: 13 May 2018, 17:34 Ok, so you have the C5 2.0 HDi 110 (DW10ATED) with Manual gearbox 5, and no Particle Filter.
Thanks for the info, i am hoping to get it on a lexia in a couple of weeks, so hopefully that'll shed some light.
russell37uk
Hell Razor5543 wrote: 13 May 2018, 17:51 I occasionally got an Anti Pollution fault on my C5 Mk1, and it turned out that the rubber pipe that connected onto the EGR had a pinhole leak at one end. Michel found it, nipped the pipe back by about 1cm, and the fault has not returned since. It could be worth checking the rubber pipes along the firewall bulkhead.
How would i check for a leak like this? - would there be a hissing sound? sorry if its a stupid question, just im not sure, as I can (and do) do basic repairs but still a novice :)
x 1999
Unread post by Stickyfinger »
You are chasing smoke if you do not get it read by a Lexia (not bog standard reader)...Lexia/Diabox systems are cheap and should be a basic part of the toolkit if you drive Pug/Citroen/DS
