Wiring diagram for xenons - 2007 mk1 facelift C5
Harlequin
x 23
Unread post by Harlequin »
Does anyone have the wiring diagram for the xenons and washer jets please for 2006 / 07 C5 Xenons? Want to retrofit some to mine
Simon
x 6946
Re: Wiring diagram for xenons - 2007 mk1 facelift C5
Here you go, unfortunately, the wiring codes are a bit nondescript. I've overlapped the second half for continuity. I've assumed you've got ESP on your vehicle - as it will need the steering wheel angle sensor for the directional function to work.
Click to zoom these
CodeDescription
2615Right-hand headlamp
2610Left-hand headlamp
MC10MC 10 Earth
6606Front body height sensor + power supply
Harlequin
x 23
Thank you marc! Looking to retrofit some directional xenons to mine , will investigate what (if any) of teh wiring is in situ already
Simon
x 6946
No problem, don’t forget you’ll need the Headlight Auto Adjustment unit too. Number 1 in the diagram. The headlamp corrector (5) should already be incorporated into the headlight unit.
Harlequin
x 23
Do you have a part number for number 1?
Simon
x 6946
6224R6 is the replacement part, and 6224K8 was the original.
Harlequin
x 23
Thank you again! Got some parts coming , so got a new project :P
Simon
x 6946
I don't envy that job - have you got all the headlamp washer rams , tubing and wash tank then? Are you replacing the bumper or drilling out the headlamp washer jets?
Harlequin
x 23
I have a 2007 facelift now and the bumper is pre cut
Simon
x 6946
Even better!
Here's all the parts of the washer for ref incase you don't have it already.
Harlequin
x 23
Will wait till better weather , but have the headlights, control box and washer jets - will check on wiring and teh washer bottle!
Simon
Dommo
x 20
Unread post by Dommo »
I’ve recently looked into this, fitted some xenon headlamps into the car, the loom powered the xenons (which only do dip beam, they are not bi-xenon), and main beam etc all corectly.
The loom for the directional portion is not there, or at least it isn’t on my VTX+
So you will never be able to get them fully functional without a new loom I’m afraid. Half the wiring is missing on the ‘lesser’ spec loom.
x 6946
Did you fit different xenons then I.e. non Citroen ones? The Proper Citroen bi-xenon for the C5 MKII works in main and dipped beam modes as well as having a second main beam standard headlamp to compliment them. So I’m guessing you have fitted some aftermarket ones then?
Harlequin
x 23
Mine is a mark 1 facelift? thought they were only directional?
Simon
x 6946
Mark I facelift or more commonly referred to as MK II (late 2004 - 2007). Yes they are bi-directional, having motors incorporated into the headlamp for levelling and directional functions. But if you don’t have the necessary kit / wiring needed for the directional functions, they will remain static in backup mode as if you had turned the directional function off.
