'09 2.0 HDi thermostat.
milleplod
- x 15
I've noticed over the last few....cold....mornings that my heater isn't getting as hot, as quickly, as it used to. I'm assuming it might be time for a new thermostat. Is it buried in the bowels of the engine bay, or a fairly easy job? Any recommends re where to source one....dealer or are aftermarket ones ok?
Pete
Pete
Nocto Diuque Venamur.
- x 1488
Re: '09 2.0 HDi thermostat.
What's the VIN? There are several different 2.0 variants and they all seem to have different units - they are all complete units, however....
- x 3565
I'm sure I read somewhere that they have a supplmentary electric heater in the vent system to provide instantaneous warmness (to call it heat would be stretching it a bit !). Part number 643691 labelled as 'resistance' looks to be the candidate for mine - this isn't the same as p/n 6441S7 labelled as 'control module'. If it's rapid heating that you're missing out on now, you might want to delve further into the 'resistance' part.
- x 6945
milleplod wrote: 26 Jan 2018, 10:37 I've noticed over the last few....cold....mornings that my heater isn't getting as hot, as quickly, as it used to. I'm assuming it might be time for a new thermostat. Is it buried in the bowels of the engine bay, or a fairly easy job? Any recommends re where to source one....dealer or are aftermarket ones ok?
Pete
Pete - have a squiz at my post here - look at part number 4 on the diagram - that is the heating resistance unit for rapid heating of the car. I think I've included access diagrams in the thread there too. This is assuming of course that you're concerned about heating shortly after starting and not when at normal operating temperature.
milleplod
- x 15
My VIN is VF7**************[VIN obfuscated, can be read by forum staff]. Warm air does come out fairly quickly tbh, within around a minute or so if I drive off straight away from cold. It just doesn't seem to get as hot as it used to......its hot enough, but I'm sure it used to be hotter!
Pete
Pete
- x 6945
Same diagram as I posted - dual zone system.
milleplod
- x 15
GiveMeABreak wrote: 26 Jan 2018, 18:45milleplod wrote: 26 Jan 2018, 10:37 I've noticed over the last few....cold....mornings that my heater isn't getting as hot, as quickly, as it used to. I'm assuming it might be time for a new thermostat. Is it buried in the bowels of the engine bay, or a fairly easy job? Any recommends re where to source one....dealer or are aftermarket ones ok?
Pete
Pete - have a squiz at my post here - look at part number 4 on the diagram - that is the heating resistance unit for rapid heating of the car. I think I've included access diagrams in the thread there too. This is assuming of course that you're concerned about heating shortly after starting and not when at normal operating temperature.![]()
I can't see your post Marc, there's no link!
Pete
demag
- x 102
Same here can't see anything.
Dave
- x 6945
Sorry guys, too much going on...
viewtopic.php?f=3&t=58862&hilit=Resistor#p555538
There are several related things going on in that thread.
- x 1488
This is the part no for the thermostat, complete outlet housing on the end of the head; including the temp sensor.
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
00001336Y9 OUTLET TANK 1 92.14 GBP 110.57 GBP 110.57 GBP
Shouldn't be too hard to fit. If the stat is not working, then you should see a drop in running temp - need one on my 307 as it struggles to make 70 unless worked hard, and the heater is not very warm!!
milleplod
- x 15
Thanks for the part number. Just been Googling - fits a lot of cars, doesn't it!
I should've added earlier that my temp gauge sometimes doesn't even show one bar, especially when its a cold day, so I think its definitely time for a new one!
Is there any special procedure for the swap does anyone know? Will I have to bleed the cooling system once its done?
Pete
Pete
EDC5
- x 130
Bleeding of the cooling system is done via the two bleed valves, one near the thermostat and the other near the bulkhead.
When I changed my coolant I opened both of these valves and added new coolant until it emerged at the first one, as it started trickling out I put the cap back on and sealed it. After adding a bit more coolant I did the same thing with the upper bleed valve.
- x 1746
How much??? ??? 1336Y9 fitted to lots of vehicles - just quickly found one on Ebay for £39. Worth shopping around.
milleplod
- x 15
EDC5 wrote: 27 Jan 2018, 10:01 Bleeding of the cooling system is done via the two bleed valves, one near the thermostat and the other near the bulkhead.
Sounds simple enough, thanks!
Pete
- x 3565
Genuine article housing £44.00:
https://www.ebay.co.uk/itm/Peugeot-307- ... 2113531326
Instructions for removal of housing:
http://www.filedropper.com/c5x7-b1gg011 ... lethousing
