'09 2.0 HDi thermostat.
milleplod
x 15
Unread post by milleplod »
I've noticed over the last few....cold....mornings that my heater isn't getting as hot, as quickly, as it used to. I'm assuming it might be time for a new thermostat. Is it buried in the bowels of the engine bay, or a fairly easy job? Any recommends re where to source one....dealer or are aftermarket ones ok?
Pete
Nocto Diuque Venamur.
x 1458
Re: '09 2.0 HDi thermostat.
What's the VIN? There are several different 2.0 variants and they all seem to have different units - they are all complete units, however....
x 3567
I'm sure I read somewhere that they have a supplmentary electric heater in the vent system to provide instantaneous warmness (to call it heat would be stretching it a bit !). Part number 643691 labelled as 'resistance' looks to be the candidate for mine - this isn't the same as p/n 6441S7 labelled as 'control module'. If it's rapid heating that you're missing out on now, you might want to delve further into the 'resistance' part. :)
x 6963
milleplod wrote: 26 Jan 2018, 10:37 I've noticed over the last few....cold....mornings that my heater isn't getting as hot, as quickly, as it used to. I'm assuming it might be time for a new thermostat. Is it buried in the bowels of the engine bay, or a fairly easy job? Any recommends re where to source one....dealer or are aftermarket ones ok?
Pete
Pete - have a squiz at my post here - look at part number 4 on the diagram - that is the heating resistance unit for rapid heating of the car. I think I've included access diagrams in the thread there too. This is assuming of course that you're concerned about heating shortly after starting and not when at normal operating temperature. :)
milleplod
x 15
My VIN is VF7**************[VIN obfuscated, can be read by forum staff]. Warm air does come out fairly quickly tbh, within around a minute or so if I drive off straight away from cold. It just doesn't seem to get as hot as it used to......its hot enough, but I'm sure it used to be hotter!
Pete
x 6963
Same diagram as I posted - dual zone system.
milleplod
x 15
GiveMeABreak wrote: 26 Jan 2018, 18:45
Pete
I can't see your post Marc, there's no link! :)
Pete
demag
x 102
Unread post by demag »
Same here can't see anything.
Dave
x 6963
Sorry guys, too much going on...
viewtopic.php?f=3&t=58862&hilit=Resistor#p555538
There are several related things going on in that thread.
x 1458
This is the part no for the thermostat, complete outlet housing on the end of the head; including the temp sensor.
00001336Y9 OUTLET TANK 1 92.14 GBP 110.57 GBP 110.57 GBP
Shouldn't be too hard to fit. If the stat is not working, then you should see a drop in running temp - need one on my 307 as it struggles to make 70 unless worked hard, and the heater is not very warm!!
milleplod
x 15
Thanks for the part number. Just been Googling - fits a lot of cars, doesn't it! :shock: I should've added earlier that my temp gauge sometimes doesn't even show one bar, especially when its a cold day, so I think its definitely time for a new one!
Is there any special procedure for the swap does anyone know? Will I have to bleed the cooling system once its done?
Pete
EDC5
x 131
Unread post by EDC5 »
Bleeding of the cooling system is done via the two bleed valves, one near the thermostat and the other near the bulkhead.
When I changed my coolant I opened both of these valves and added new coolant until it emerged at the first one, as it started trickling out I put the cap back on and sealed it. After adding a bit more coolant I did the same thing with the upper bleed valve.
x 1751
How much??? ??? 1336Y9 fitted to lots of vehicles - just quickly found one on Ebay for £39. Worth shopping around.
milleplod
x 15
EDC5 wrote: 27 Jan 2018, 10:01 Bleeding of the cooling system is done via the two bleed valves, one near the thermostat and the other near the bulkhead.
Sounds simple enough, thanks! :)
Pete
x 3567
