Timing belt on C5 x 7
KennyW
x 165
Unread post by KennyW »
Question to all with the knowledge,
The fitting guide as per citroen service says tighten belt to max position and rotate belt for 6 full turns and reposition to normal position.
My question refers to a you tube video of someone doing said belt and turning eccentric tensioner to normal position and turning belt around twice.
Any thoughts ?
Kenny
C3 1.4 petrol (SWMBO)
411514
(Donor 2017)
x 39
Re: Timing belt on C5 x 7
Unread post by 411514 »
The initial tension isn’t particularly critical. I usually tighten to near-max for the first five turns out of habit. I assume that the only advantage to over tensioning for the first turns is to test that the various pulleys are sound.
Sam
2003 C5 2.0HDI 110
KennyW
x 165
Thanks Sam
