Xantia TD thermostat
mark_sp
Unread post by mark_sp »
Does the cooling system really need to be drained to swap the thermostat ?
Mark
jeremy
x 3
Unread post by jeremy »
No. Did our ZX 1.9D just by undoing the thermostat housing and letting the water out. You will still have to bleed it. I simply tipped a gallon plastic antifreeze container full of water into the filler neck and then opened the valves. Surprisingly little leakage and I was able to pressurise the system by squeezing the container a bit.
Jeremy
mark_sp
Mark
