hi, abs light on and showing non function been to local garage for a diagnostic check and says"no communication with ecu"they think ecu faulty
(brakes work fine but abs doesn't seem to come in when I try emergency stop... wheels skidded)
just wondering if its been encountered before if so what are causes
the vehicle is a 2005 1.6 8v petrol
many thanks in advance
xsara picasso abs non function
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 232
Re: xsara picasso abs non function
AFAIK, causes can be broken wire/connector, damaged, obstructed or misaligned reluctor ring or sensor (all of which you have x4) or as your local garage opined, the rather expensive ECU, it's wiring and fuse(s).
