xsara picasso abs non function
krl696
Unread post by krl696 »
hi, abs light on and showing non function been to local garage for a diagnostic check and says"no communication with ecu"they think ecu faulty
(brakes work fine but abs doesn't seem to come in when I try emergency stop... wheels skidded)
just wondering if its been encountered before if so what are causes
the vehicle is a 2005 1.6 8v petrol
many thanks in advance
MikeT
x 232
Re: xsara picasso abs non function
Unread post by MikeT »
AFAIK, causes can be broken wire/connector, damaged, obstructed or misaligned reluctor ring or sensor (all of which you have x4) or as your local garage opined, the rather expensive ECU, it's wiring and fuse(s).
