different car giving me bags of trouble
darbuck
x 291
Unread post by darbuck »
Hi Guys I havent been on for a while I have been super busy doing an honours degree in energy engineering anyway the C5 died so I bought a nissan maxima 01 ran ok but was a bit iffy cut out the odd time but now I sorted that the car wont hold idle between 1500 and 3500 any suggestions as to what could be causing this. :hb: :help2:
Darren
x 6963
Re: different car giving me bags of trouble
Moved from the Citroen Technical Forum - Sorry to hear about your C5 - you may get some general advice concerning your Nissan, but we don't really do other makes here. :wink:
x 2943
Look up 'How to clean the IACV' that's the most common reason for your fault.
darbuck
x 291
Hi Marc, I know, I just think the expertise on this forum can help me. respect to all here.
Darren
Darren
darbuck
x 291
Hi Gibbo, how are you I tried cleaning IACV I ave actually replaced it and still the same problem I am going to pull the well hidden ecu to to see if the driver is blown but I checked it before and it was fine. I have also replaced TPS and Knock sensor. 8-[
Darren
x 5621
GiveMeABreak wrote: 19 Jun 2017, 10:55 Moved from the Citroen Technical Forum - Sorry to hear about your C5 - you may get some general advice concerning your Nissan, but we don't really do other makes here. :wink:
But it is French-ish surely!
Can't assist with the problem though, sorry.
I imagine a diagnostic session would be the first thing to try, might narrow down the possibilities.
darbuck
x 291
Hi myglaren I tried running a diagnostic, no faults coming up so maybe a vaccuum leak, or faulty new TPS. she just isnt as talkative as a C5. I will keep trying, I think I will try to build a smoke machine and try to find a leak, if there is one. I am going to have to try to work blind on this one. Thanks guys if I make any progress I will let you know.
Darren
wurlycorner
x 272
Unread post by wurlycorner »
Idle between 1500 & 3500?
The engine shouldn't be idling that high anyway???
Iain
CX DTR T2 Safari (silver)
darbuck
x 291
Hi Wurly, I know it sounds mental but its for the emmissions test it just keeps hunting up and down so they cant complete the test which means I cant get an NCT the same thing as an MOT just with a bit more beurocracy and non mechanic testers that can only follow the computer readout.But that aside she wont run steady and tends to hesitate and surge so not exactly safe to drive so I have it off the road at present. pain in te rear end. I have a loan of a pug 205 wich is a good little motor but uncomfortable for a 140 mile round trip to work.
Darren
wurlycorner
x 272
Ah right, gotcha...
Have they not got a generic OBD diagnostic tester that can tell them what is going on?
Iain
darbuck
x 291
Hi Wurly, yeah I have a delphi and wurth wow knock off which gives a good bit of info there is only one code for a knock sensor but that shouldnt cause this kind of issue should it ? unless it is preventing idle relearn but It was doing tis long before the knock sensor became an issue obviously it could have been failing but I think tere is another issue I ave attached some readings if someone can tell me if they look mental to them too. any ideas this is going on months now the car is off the road since march.
Darren
darbuck
x 291
Hi guys update on this the bank1 sensor 2 O2 sensor is constantly reading lean does this mean it is kaput
Darren
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
hi Dar, i had similar lean banks on someones BM last week.. said I would take a look..
the rubber pipe from MAF to inlet was perished..! i spent a bit of time before finding this.. and at the moment do not know if i have cured the lean banks.. I hope I have !
John
darbuck
x 291
Hi John, I actually replaced the rubber boot between the Maf and throttle body and I have replaced the vaccuum lines could it be the sensor, I done a smoke test but couldnt see anything. I am beginning to think its electronic but cant be sure.
Thanks John by the way
Darren
