Xantia Estate > Trunk cover hooks 3D print
longgo
x 3
Unread post by longgo »
Hi folks,
There was request from mate of mine if there is any chance to be made something about broken hooks for that trunk blind / cover. One option is 54e for set from Citroen or.. 3D printed new ones.
I spent some time measuring, modelling and test so here is some result that is kind`a OK for use / print.
Here are ready 3d STL files :
[The extension zip has been deactivated and can no longer be displayed.]
and in case you wish to see them as 3D object use that site: http://www.viewstl.com/
post notes:
There are 2 set of files. One is "clean" and is your choice how to print it, the other help my printer. I mean that with the "helper claws" give me good result on PLA print on cold bed. My first attempts even with OEM printer software helpers end as that:
Hope that will help someone else also :)
c.morewood
x 55
Re: Xantia Estate > Trunk cover hooks 3D print
Unread post by c.morewood »
I don't suppose you could make the rear brake disc protectors like that. If they would stand the heat.
They're E90 from Germany for a pair. I had thought of making a pair from fiberglass.. but printing them might be a better option. I'm sure there'll be quite a demand.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
ekjdm14
x 271
Unread post by ekjdm14 »
That would be a great idea if, as you say, they'd stand the heat. Part of me thinks not as the basis of printable plastic is thermoplastics (not sure if there's a similar technique for thermosetting plastics? would be better) but then the other part of me says yes, as the back brakes don't do an awful lot on a Xantia... They'd likely be good sellers though if someone made rust proof replacements
'95 Xantia LX 1.9D-auto, Black, 123k
'96 ZX SX 1.9TD, White, 90k
'12 Mini freebie project
elma
x 284
Unread post by elma »
A resin printer would be more suitable for that purpose.
High temp resin cured by light is much more likely to fit the bill.
I expect either would be too brittle though.
longgo
x 3
heh.. I was almost sure they are made from steel not plastic.Them protectors I mean.. But with watercut machine will be easy to produce from stainless steel. The problem is the profile. Well perhaps one wooden shape and when is ready watercuted from aluminium for example then hummer it over the shape(as mud car fenders in 30`s) and ta daaa :)
longgo
x 3
As time passed, I have to 3D print another set of that hooks, so I rework the file:
Now is with better design and easy or say proper for 3D print. As you can see from my screenshots, the vertical print come the clean one. Or in case you have access to 3D printer with PVA (water dissolving filament) , then better print it horizontally. My settings was 0.2mm per layer , 0.3mm initial layer, coolant from 3th layer, and wall count -> 3 , infill 25-35%
In some part of the topic was question for the option to 3D print some break guards or something as that. There are already industrial 3D printers that can produce parts from metal but will cost quite a lot.
The next option is to 3D print the part, and use it as mold core. Then when the material dry, you burn the plastic and pour the metal in it.. Still, quite rough to do it at home kitchen or garage... :-D
x 6950
I must of missed your original post, but just picked it up on your update.
Thanks for uploading and updating this - very useful for Xantia owners!
longgo
x 3
My pleasure!
longgo
x 3
Small update : due ZIP file been blocked (maybe even the links that contain it) , if someone is still searching for them files, here is topic in my blog that include them: https://longgo.eu/?x=entry:entry170528-141630
