Citroen C5 P0500 Vehicle speed signal fault : Value received incorrect
northface
Unread post by northface »
Got a P0500 Vehicle speed signal fault : Value received incorrect from Lexia. It sets the MIL light and gives a "Depollution system faulty" message.
What causes this? The speedometer works fine. Where does the ECU take this signal from? I can't find any sensor on the gearbox.
All info and ideas appreciated!
x 5689
Re: Citroen C5 P0500 Vehicle speed signal fault : Value received incorrect
IIRC it comes from the ABS circuit.
Välkommen :) :welc:
northface
OK. I've recently replaced a front wheel bearing. Maybe something went wrong there..
x 5689
Yes, possible damage to the ABS sensor or wiring or even (less probable) the reluctor ring.
ell270390
Unread post by ell270390 »
Agree with myglaren! Also when you fitted the wheel bearing did you fit it the correct way round with the magnetic pickup on the inside
northface
OK. I put the black side on the bearing facing inwards. (I hope..)
ell270390
Yeah black side is pickup hopefully you have put it the sensor side I'd re-check that's correct first! Unless obvious damage to speed sensor or wiring
