Hi,
Got a P0500 Vehicle speed signal fault : Value received incorrect from Lexia. It sets the MIL light and gives a "Depollution system faulty" message.
What causes this? The speedometer works fine. Where does the ECU take this signal from? I can't find any sensor on the gearbox.
All info and ideas appreciated!
Citroen C5 P0500 Vehicle speed signal fault : Value received incorrect
northface
- x 5674
Re: Citroen C5 P0500 Vehicle speed signal fault : Value received incorrect
IIRC it comes from the ABS circuit.
Välkommen
Välkommen
northface
OK. I've recently replaced a front wheel bearing. Maybe something went wrong there..
- x 5674
Yes, possible damage to the ABS sensor or wiring or even (less probable) the reluctor ring.
ell270390
Agree with myglaren! Also when you fitted the wheel bearing did you fit it the correct way round with the magnetic pickup on the inside
northface
OK. I put the black side on the bearing facing inwards. (I hope..)
ell270390
Yeah black side is pickup hopefully you have put it the sensor side I'd re-check that's correct first! Unless obvious damage to speed sensor or wiring
