Home audio systems
x 1060
Home audio systems
Unread post by wheeler »
Does anybody on here know anything about home audio systems ?
One of my rear surround speakers has packed in so I have bought another set off ebay. The impedance of the original speakers is 3 ohms but the new ones I have are 8 ohms. Can these be used straight onto my system ? I have not tried connecting them yet as I don't know if it can damage the system by using a different impedance ? If they are ok to use will it affect sound quality ? or is it best to get same rating ?
Mandrake
x 695
Re: Home audio systems
Unread post by Mandrake »
Connecting an 8 ohm speaker to an amplifier designed for a 3 ohm speaker won't cause any damage, (the reverse is not true) but given the differences between old and new speakers (differences in impedance are the least of your worries!) just changing some of the speakers to something very different is not likely to give good results. At the very least you're going to have to re-adjust the volume balance between old and new speakers as their sensitivity will be different, and the frequency response of the speakers is also likely very different.
Depends how fussy you are I suppose!
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 8441
Simon, I second what you say...
x 1746
Another similar vote. Going from 3 to 8-ohm won't be a problem, but you may have to increase the volume setting for the rears a tad.
lexi
x 133
Unread post by lexi »
Ohms Law.............resistance is futile :lol:
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 1746
Watt was that ?
x 5679
lexi wrote:Ohms Law.............resistance is futile :lol:
Impedance in this case though.
x 1240
Unread post by Peter.N. »
Have you actually tested the old speaker to make sure it is duff? Swapped it with the other channel?
x 1060
Yep, swapped the units L to R & the fault moves with the speaker.
x 1240
Fair enough, its pretty rare for speakers to fail. As already mentioned it wont do any harm to use an 8 ohm speaker so give it a try.
x 1060
The said speaker is actually pretty much brand new. I bought the system about 6-7 years ago but only ever set up the fronts & sub because the living room setup at the time wasn't really ideal for rear speakers & knew I would be moving house but I did plug them in at the time with the wires trailing across the floor just to try them out & they were ok. Since then they have been sat back in the box in the loft for a few years, recently I was going to set them up again in this house & found this one wasn't working. I have had the speaker apart & there is nothing visibly amiss inside.
x 1240
Check the resistance across the speech coil, should be pretty low probably an ohm or two, if that reads OK you have a fault in the lead/plug somewhere. If you don't have a meter connect a 1.5 volt battery across it, you should hear it crackle.
x 2007
Unread post by Stickyfinger »
No Impedance here now
