Home audio systems
Post Reply
My Cars:
x 730
Home audio systems
Post by wheeler »
Does anybody on here know anything about home audio systems ?
One of my rear surround speakers has packed in so I have bought another set off ebay. The impedance of the original speakers is 3 ohms but the new ones I have are 8 ohms. Can these be used straight onto my system ? I have not tried connecting them yet as I don't know if it can damage the system by using a different impedance ? If they are ok to use will it affect sound quality ? or is it best to get same rating ?
My Cars:
x 666
Re: Home audio systems
Post by Mandrake »
Connecting an 8 ohm speaker to an amplifier designed for a 3 ohm speaker won't cause any damage, (the reverse is not true) but given the differences between old and new speakers (differences in impedance are the least of your worries!) just changing some of the speakers to something very different is not likely to give good results. At the very least you're going to have to re-adjust the volume balance between old and new speakers as their sensitivity will be different, and the frequency response of the speakers is also likely very different.
Depends how fussy you are I suppose!
My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
x 6183
Contact:
Post by CitroJim »
Simon, I second what you say...
Runner, cyclist, time triallist, duathlete, Citroen AX fan and the CCC Citroenian 'From A to Z' Columnist...
My Cars: 1996 XM 2.5TD Exclusive hatch RHD
and lots of Rovers before that: 1935 Ten, 1947 Sixteen, 1960 P5 3-litre, 1966 P6 2000, 1972 P6 2000TC, and 1975 P6B 3500S
x 1752
Post by white exec »
Another similar vote. Going from 3 to 8-ohm won't be a problem, but you may have to increase the volume setting for the rears a tad.
lexi
My Cars:
x 138
Post by lexi »
Ohms Law.............resistance is futile :lol:
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 1752
Watt was that ?
My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX
x 4920
Post by myglaren »
lexi wrote:Ohms Law.............resistance is futile :lol:
Impedance in this case though.
My Cars: Currently:
C5 X7 VTR + Satnav Hdi estate Silver
C5 X7 VTR + Hdi Estate 2008 Red
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars.
x 1205
Post by Peter.N. »
Have you actually tested the old speaker to make sure it is duff? Swapped it with the other channel?
My Cars:
x 730
Post by wheeler »
Yep, swapped the units L to R & the fault moves with the speaker.
My Cars: Currently:
x 1205
Post by Peter.N. »
Fair enough, its pretty rare for speakers to fail. As already mentioned it wont do any harm to use an 8 ohm speaker so give it a try.
My Cars:
x 730
Post by wheeler »
The said speaker is actually pretty much brand new. I bought the system about 6-7 years ago but only ever set up the fronts & sub because the living room setup at the time wasn't really ideal for rear speakers & knew I would be moving house but I did plug them in at the time with the wires trailing across the floor just to try them out & they were ok. Since then they have been sat back in the box in the loft for a few years, recently I was going to set them up again in this house & found this one wasn't working. I have had the speaker apart & there is nothing visibly amiss inside.
My Cars: Currently:
x 1205
Post by Peter.N. »
Check the resistance across the speech coil, should be pretty low probably an ohm or two, if that reads OK you have a fault in the lead/plug somewhere. If you don't have a meter connect a 1.5 volt battery across it, you should hear it crackle.
My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally
x 1290
Contact:
Post by Stickyfinger »
No Impedance here now
Activa, the Moose Rider
3x C5x7 Steering racks and counting
Post Reply
