Hi.
I recently intended to change my front wheel bearing. On inspection, the noise wasnt the bearing, but stupidly damaged the abs sensor. I have installed a new one, admittedly, a cheap fleabay item.
Before I did any work, the ESP light would come on occasionally, but NEVER the abs warning light.
Since I put the new sensor in, the abs has worked, but generally doesnt, and the warning light is on. I have a cheap code reader, and have disconnected battery, cleared faults (P1599) but the abs warning is still on.
Can anyone shed any light on this problem before I start stripping everything out again?
407 ABS fault
elma
- x 284
Re: 407 ABS fault
Check the resistance of the new sensor would be my first place to look. If it's a cheap ebay one it could be out of spec. After that it's outside my experience, I'd be asking too.
pogo001
Re: 407 ABS fault
Good idea, but do you have any idea of what the resistance should be? If not, Ill check the other side first.
elma
- x 284
Re: 407 ABS fault
Not sure the values but the above video should explain all.
pogo001
Re: 407 ABS fault
Ill give that a try too. Thanks.
elma
- x 284
Re: 407 ABS fault
Hope it is helpful, my internet is struggling so much I can't watch it myself.
I'm sure if you google 407 abs sensor resistance you will get a value.
I'm trying to work and look at the forum on a satellite connection and for the last couple of days it's been quite poor so I can do the bear minimum.
demag
- x 102
Re: 407 ABS fault
If you disconnected the battery don't you have to do a bsi reset on that model?
Sent from my A0001 using Tapatalk
Dave
Peugeot_Russ
Re: 407 ABS fault
Get a new genuine peugeot planet lexia system from ebay (easydiagnostics.co.uk) sells the best ones. Do a scan and check the characterization of the fault. It could be a simple issue of a cheap sensor vs. genuine peugeot or german made sensor for the 407s.
or if you find a garage/dealer/person who has the genuine peugeot planet, then give them a check. i
