Peugeot 206 driverside driveshaft?
Btopley1997
I am having a problem with getting the drivers side drive shaft will only go in so fair any help
ekjdm14
- x 262
Re: Peugeot 206 driverside driveshaft?
Where the centre support bearing is, there's 2 eccentric bolts that you would have loosened and turned through 180* to release the bearing on removal. First things first would be to make sure one or both of them haven't turned back round and blocked progress. Also I found, during the clutch job on our 1.4HDi that, if there's any corrosion/dirt in the bearing housing this can obstruct it too. This assumes you've compared old and new and the spline pattern is definitely correct. Hope this helps.
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
- x 1939
I read the OPs post as having problems getting the drive shaft back in. Perhaps he could confirm one way or the other.
spider
- x 77
I concur. Is the problem fitting the shaft into the diff housing or is the problem the shaft itself will not move through the bearing housing ?
I'd suspect the latter (may need to clean the housing a little if the bolts are not in the way) the former is quite rare I think for the pinions to move out of mesh and jam. Not impossible but not common.
Andy.
