Pete
Which gearbox....
milleplod
- x 15
Which gearbox....
.....have I got in my '09 C5 HDi 138 auto? I was thinking that at 70k miles it might be wise to get the oil in it changed. Its the 6-speed box, but searching on here seems to tell me there are 2 different boxes fitted.
Pete
Pete
Nocto Diuque Venamur.
Sloppysod
- x 397
Re: Which gearbox....
Yes you may very well be right, best if you either post you VIN, someone will look on the Citroen Service site and should be able to identify the correct gearbox.
or even set up an account for yourself, http://service.citroen.com/pages/index.jsp
Stu
- x 6945
You have the AM6 (AMC1) Aisin Gearbox fitted. Many recommend getting the oil changed as the there can be some issues with debris in the oil, which can affect the hydraulic block causing issues. I've heard of some changing the oil at 30k and it was filthy! Don't believe the 'sealed for life' declarations as that is open to interpretation of what is the 'life' of a gearbox. It is essential to use the correct oil (and this can be expensive from the dealer), but I would suggest you change it at your mileage.
milleplod
- x 15
Thanks for the replies chaps, appreciated.
So, I'm thinking the fluid is the 3309 stuff, or equivalent....let Googling commence!
Pete
Pete
