chaps, on an hdi injector (a bosch one) there are 3 numbers.. 2 are in the same place/plane - starting 044 and Z and the third is longer and on 3 rows and in a different part of the injector head..
if my first 2 numbers match an injector I have found online, can i assume they are the same or is there more to it :O
I had a quick look at documentation last night and it looked a mine field..
Mine are fitted into an 8V 2.2 and the one i am looking at is from an 8v 2.0
many thanks
John
2.2 hdi 8v questions
- x 6957
Re: 2.2 hdi 8v questions
John, they do seem to be different depending on the engine. Did you see my previous post here on identifying the codes: http://www.frenchcarforum.co.uk/forum/v ... ng#p496576jgra1 wrote:chaps, on an hdi injector (a bosch one) there are 3 numbers.. 2 are in the same place/plane - starting 044 and Z and the third is longer and on 3 rows and in a different part of the injector head..
many thanks
John
Have a look here too: http://www.commonraildiesels.com/index. ... 49_451_473
( this was based on a C5 2.2 search) and you can see they are different depending on the engine code. What is the VIN?
jgra1
- (Donor 2021)
- x 37
will take a look marc. you have the vin
its an odd case .. 2.2 8v not the common 16v
jgra1
- (Donor 2021)
- x 37
rhy is the 2.0
4hy is the 2.2 I think
- x 6957
aahh that one John!
jgra1
- (Donor 2021)
- x 37
just rechecked my pics from.last night
the injector I removed from my old 110 c5 has exactly the same number as the one I removed from the 2.2
saying that ..the one I removed could be the wrong one anyway due to.previous owner...
either way .. i will check. the other 3 2.2 ones later
a piece of a jigsaw is starting to fit into place....
- x 6957
Quite likely they are definitely different between those engines!
- Boxer / Relay - still can't decode this one proprely, but these are the ones they show for the Boxer:
http://www.commonraildiesels.com/index. ... 05_207_229
jgra1
- (Donor 2021)
- x 37
hmm.that shows the same thing.. the bosch 2.0 and 2.2 have same part nos. ...
which tyes in with what I found last night .
if so, the engine has increased by 200cc and the injectors haven't changed .. the ecu is getting the finger pointed here
- x 6957
Yes - was still on the C5 page!, those are the same John as you say - so looks like you have the answer at lastjgra1 wrote:hmm.that shows the same thing.. the bosch 2.0 and 2.2 have same part nos. ...
jgra1
- (Donor 2021)
- x 37
how the horsepower goes down , the torque is the same and the cc goes up 200 baffles.me
but if she ever runs she isn't going to get a remap more like a new atlas !
thanks marc
- x 1487
It presumably makes more torque at low revs, which is more appropriate for van useage!
jgra1
- (Donor 2021)
- x 37
thanks richard
but I think the max torque is 250 nm for both the 2.0 and 2.2 ... will check again later
- x 1942
What vehicle is that fitted in?jgra1 wrote:its an odd case .. 2.2 8v not the common 16v
jgra1
- (Donor 2021)
- x 37
hi Paul. a boxer 2 or relay
2002 2006
2002 2006
- x 1942
How curious. Does it have the balancer shaft of the 16v do you know?
