2.2 hdi 8v questions
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
chaps, on an hdi injector (a bosch one) there are 3 numbers.. 2 are in the same place/plane - starting 044 and Z and the third is longer and on 3 rows and in a different part of the injector head..
if my first 2 numbers match an injector I have found online, can i assume they are the same or is there more to it :O
I had a quick look at documentation last night and it looked a mine field..
Mine are fitted into an 8V 2.2 and the one i am looking at is from an 8v 2.0
many thanks
John
x 6950
Re: 2.2 hdi 8v questions
jgra1 wrote:chaps, on an hdi injector (a bosch one) there are 3 numbers.. 2 are in the same place/plane - starting 044 and Z and the third is longer and on 3 rows and in a different part of the injector head..
many thanks
John
John, they do seem to be different depending on the engine. Did you see my previous post here on identifying the codes: http://www.frenchcarforum.co.uk/forum/v ... ng#p496576
Have a look here too: http://www.commonraildiesels.com/index. ... 49_451_473
( this was based on a C5 2.2 search) and you can see they are different depending on the engine code. What is the VIN?
jgra1
(Donor 2021)
x 36
will take a look marc. you have the vin ;)
its an odd case .. 2.2 8v not the common 16v
jgra1
(Donor 2021)
x 36
rhy is the 2.0
4hy is the 2.2 I think
x 6950
aahh that one John!
jgra1
(Donor 2021)
x 36
just rechecked my pics from.last night
the injector I removed from my old 110 c5 has exactly the same number as the one I removed from the 2.2
saying that ..the one I removed could be the wrong one anyway due to.previous owner...
either way .. i will check. the other 3 2.2 ones later
a piece of a jigsaw is starting to fit into place....
x 6950
Quite likely they are definitely different between those engines!
- Boxer / Relay - still can't decode this one proprely, but these are the ones they show for the Boxer:
http://www.commonraildiesels.com/index. ... 05_207_229
jgra1
(Donor 2021)
x 36
hmm.that shows the same thing.. the bosch 2.0 and 2.2 have same part nos. ...
which tyes in with what I found last night .
if so, the engine has increased by 200cc and the injectors haven't changed .. the ecu is getting the finger pointed here
x 6950
jgra1 wrote:hmm.that shows the same thing.. the bosch 2.0 and 2.2 have same part nos. ...
Yes - was still on the C5 page!, those are the same John as you say - so looks like you have the answer at last :-D
jgra1
(Donor 2021)
x 36
:-D
how the horsepower goes down , the torque is the same and the cc goes up 200 baffles.me
but if she ever runs she isn't going to get a remap more like a new atlas ! :)
thanks marc
x 1504
It presumably makes more torque at low revs, which is more appropriate for van useage!
jgra1
(Donor 2021)
x 36
thanks richard
but I think the max torque is 250 nm for both the 2.0 and 2.2 ... will check again later
x 1955
jgra1 wrote:its an odd case .. 2.2 8v not the common 16v
What vehicle is that fitted in?
jgra1
(Donor 2021)
x 36
hi Paul. a boxer 2 or relay
2002 2006
x 1955
How curious. Does it have the balancer shaft of the 16v do you know?
