Where do i get.....
Stinkwheel
Where do i get.....
Unread post by Stinkwheel »
.... a new or good used XUD diesel injector with needle lift sensor for a 97 Xantia TD?
Im more into older cits usually and this is a bit new for my understanding :-)
Many thanks folks.
"Rust Never Sleeps" said Neil Young. Did he own old citroens?
1998 Xantia TD exclusive auto estate +3 x BX's +77' ami 8 break + 73' dyane 6 + '83 2CV6 + 94' XM 2.1 sx auto + 89' XM2.0i
+ '85' GSA + '97 XM 2.0 16v + '81 Visa super E
Bick
x 44
Re: Where do i get.....
Unread post by Bick »
I got my last one from GSF
x 8300
Injectors with the Needle Lift Sensor are both rare and expensive now...
Scour scrappies and have one refurbished by a local diesel specialist is likely your best bet...
Why do you ask? Do you have a duff one?
Stinkwheel
We do indeed have a duff one Jim. Usual symptoms (in fact I believe you may even have had a look at this car in the past with your diagnostic wizardry)
If I say silver auto exclusive estate with black leather you may remember.
x 8300
Stinkwheel wrote: If I say silver auto exclusive estate with black leather you may remember.
Yes, I most certainly do!!! It's a good car that and well worthy a bit of work to make it excellent...
I did indeed diagnose a duff NLS on it...
I know the NLS is not amenable to easy repair as I've tried but i do wonder if there may be a way around it and fabricate some sort of substitute NLS..
Have you had a chat with a local diesel specialist about refurbishing an NLS equipped injector and making the NLS bit work again?
Stinkwheel
that's my next step I think. It is indeed a car worthy of bringing up to being nice, Charlotte will enjoy it as her daily driver once we have done so - it will give the BX 19TRS a rest as well.
Stinkwheel
Bick wrote:I got my last one from GSF
Can I ask when that was? Or if you still happen to have the part number on a receipt? I tried asking. But the local branch were clueless.
Bick
x 44
Its been a while maybe 2007 i sold the car a while ago and all the receipts went with it sorry.
It all depends who you talk to at GSF some of them can be low on knowledge
x 8300
Stink, where are you in the UK?
x 1751
Stinkwheel wrote:. . . it will give the BX19TRS a rest as well.
Didn't realise the fleet included a BX :P.
Are these new bits any use to you?
96 081 712 Clutch Cable (L=1455mm, for RHD) - for 1580cc, 1905cc
Pair of front discs, 266mm diam x 10mm thick, non-vented (= 95 661 746)
Set of Abex front brake pads (= 95 624 484)
Two sets of Abex rear brake pads (= 95 650 890)
Stinkwheel
Jim,
We are in wellinborough area.
And white exec, I'm sure they would be of some use to us eventually. We have got 5 ish bx's currently. The fleet list needs sn update :-)
x 1751
PM on its way to you.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Just to update this to fb levels.. i may have one or so of these.. but not a huge promise.. might take some looking for...
A very sad...
1994 XM 2.1 d auto
Stinkwheel
citroenxm wrote:Just to update this to fb levels.. i may have one or so of these.. but not a huge promise.. might take some looking for...
keeping my fingers crossed :-)
