fuel filter
Taximan
fuel filter
Unread post by Taximan »
Hi can anyone tell me how to change the fuel filter on a 2.0 HDI c5 please.
had a look and am not to sure on the procedure on how to open the pot to change the filter.
Many thanks
Citroen c5 2.0 HDI
Year 05
Vin no : VF7**************[VIN obfuscated, can be read by forum staff] 76601045
x 5688
Re: fuel filter
If it is like mine, with a locking ring around the top,
I use a pair of oil filter pliers to shift it after disconnecting the hoses.
I usually remove the bowl and make sure it is clean too - the lift pump can generate some swarf as it starts to break down which will destroy the diesel pump if it gets into it.
I did have a few flakes of gold-coloured swarf in the previous C5 that fortunately came to nothing, perhaps because I cleaned the swarf out prior to fitting a new filter.
Taximan
Re: fuel filter
Mines different but thanks for your input.
Cheers
Citroen c5 2.0 HDI
Year 05
x 2008
Re: fuel filter
Unread post by Stickyfinger »
Taximan wrote:Hi can anyone tell me how to change the fuel filter on a 2.0 HDI c5 please.
Many thanks
IF you put the Age/engine of your C5 in your Signature, then it will stop people guessing what you have.
The best bet is post the Vin number....
You can also join Citroen Service to check part numbers and parts prices.
http://service.citroen.com/socle/?start=true
JohnD
(Donor 2022)
x 72
Re: fuel filter
Unread post by JohnD »
Is it like this one? If so remove the fuel pipes by pressing down on the white tabs. Also the connector. Use a close fitting socket to unscrew the lid and use a new rubber ring.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Taximan
Re: fuel filter
Yip that's the one
Am not to clever with computers a don't no how to put stuff into the box that you stated to stop people guessing thanks but my vin number is.
Citroen c5 2.0 HDI
Year 05
x 1484
Re: fuel filter
Unread post by xantia_v6 »
Taximan wrote:Yip that's the one
  • At the very top right hand corner of this page, you will see your user name.
  • Click on the little triangle to the right of that, and select "User Control Panel" in the drop-down menu.
  • About 1/3 of the way down that page you will see a tab labeled "Overview", click the tab to the right of this which just has 3 bars on it, then select "Profile" in the drop-down menu.
There you can change the profile settings that you gave when you joined the forum, and update "My Cars", "Location" etc.
Taximan
Re: fuel filter
Thanks will do
Citroen c5 2.0 HDI
Year 05
