Wiring digram for Citroen DISPATCH I & II TYPE
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
A friend of mine has the following Citroen Dispatch make year 2006
DISPATCH I & II TYPE 800 SHORT SIDE WINDOW VAN 2.0 HDi (DW10BTED+) Manual gearbox 5
Does any one have a wring diagram ?
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 6954
Re: Wiring digram for Citroen DISPATCH I & II TYPE
There are hundreds of wiring diagrams, dependent on exact model and options, so you would have to specify for what component you want one for, as these are individually generated at component / equipment level. Also a VIN would be needed to identify the equipment fitted to the vehicle before the correct diagrams are generated.
Supply the VIN and the component you want and we might be able to help. :)
lancia58
(Donor 2022)
x 8
Hi
The wiring to the CPH ( the module that communicates with the remote key and immobilizer ) especially related fuse/s and power feed. Its a LHD and the VIN is : VF7**************[VIN obfuscated, can be read by forum staff]
Zohar
x 6954
lancia58 wrote:Hi
Zohar
All Sent :wink:
lancia58
(Donor 2022)
x 8
Hi Marc
Thanks a lot the info you sent is very helpful. I sent you an Email with some info I may need , hope you have it
Regards
Zohar
