Hi
A friend of mine has the following Citroen Dispatch make year 2006
DISPATCH I & II TYPE 800 SHORT SIDE WINDOW VAN 2.0 HDi (DW10BTED+) Manual gearbox 5
Does any one have a wring diagram ?
Wiring digram for Citroen DISPATCH I & II TYPE
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
- x 6950
Re: Wiring digram for Citroen DISPATCH I & II TYPE
There are hundreds of wiring diagrams, dependent on exact model and options, so you would have to specify for what component you want one for, as these are individually generated at component / equipment level. Also a VIN would be needed to identify the equipment fitted to the vehicle before the correct diagrams are generated.
Supply the VIN and the component you want and we might be able to help.
lancia58
- x 8
Hi
The wiring to the CPH ( the module that communicates with the remote key and immobilizer ) especially related fuse/s and power feed. Its a LHD and the VIN is : VF7**************[VIN obfuscated, can be read by forum staff]
Zohar
Zohar
- x 6950
All Sentlancia58 wrote:Hi
Zohar
lancia58
- x 8
Hi Marc
Thanks a lot the info you sent is very helpful. I sent you an Email with some info I may need , hope you have it
Regards
Zohar
Regards
Zohar
