service.citroen not allowing log in??
Timmo
- x 168
tried a few times lately and keep getting a message pop up that i can only gather is an error message and please contact administration, its in french and my french is Shocking at best, is it just me or is it not letting non Official peeps in anymore???
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
- x 1751
Re: service.citroen not allowing log in??
OK at the moment, but have had this twice.
Each time, same cause: According to Google, my IP address was in one country (Ukraine!), but Citroen have me in another (Spain, which is correct). The country mismatch is not acceptable to Citroen, and must match the country which Cit has you down as.
It is fixed by checking out your IP address and location-according-to-google, iirc, and correcting it.
Paulmi16
- x 3
I tried this but my IP address was in the United Kingdom. I found that if I set the country to English (United Kingdom) in the bottom right hand corner before logging in, then the log in was allowed
Timmo
- x 168
The country made little difference when I tried, didn't make much difference from tablet or main computer, will check IP's dreckly.
'58 C2 Code
'58 C2 Code
- x 1751
If you really get stuck, just contact the Citroen administrators, and let them know you are unable to log on. Last time I did this, they sorted the problem their end, and I was back up and running with a couple of days.
Timmo
- x 168
Checked on my phone and it worked okay, will see what settings are different and change them a bit!
'58 C2 Code
'58 C2 Code
