Xantia 2.0 hdi
bill hughes
Xantia 2.0 hdi
Bit of a basic question but can someone please tell me do the brakes, steering and suspension all work off the LHM fluid as I am trying to trace a leak, first noticed that the little yellow disc was at a low level and the STOP light stayed on, many thanks
- x 1504
Re: Xantia 2.0 hdi
Yes
Where is it wet on the bottom? There are several common candidates, depending on where it is leaking!
- x 2008
bill hughes
Re: Xantia 2.0 hdi
Thanks for your reply Richard, I am hoping to get it up on a ramp tomorrow to establish where the leak is.
bill hughes
Re: Xantia 2.0 hdi
Hi Richard, I have found the problem fortunately its a pipe that has fractured, difficult to describe but its close to the bottom sphere in front of the engine, it goes from a plastic part up to a metal pipe, Citroen main agent only I guess.
Cheers Bill
Cheers Bill
bill hughes
Re: Xantia 2.0 hdi
Further to my last post, the rubber pipe is fitted with crimped hose clips, do you think jubilee clips would do the job ok, Thanks.
- x 8458
Re: Xantia 2.0 hdi
Generally they're re-usable Bill and if possible do re-use them and they put even pressure all around the pipe which is something a Jubilee clip will not do. I always do and have the special tool for them but a pair of carpenter's pincers often work well and even a pair of side-cutters intended for snipping wires can work well to close them back up.bill hughes wrote:Further to my last post, the rubber pipe is fitted with crimped hose clips, do you think jubilee clips would do the job ok, Thanks.
Pop them off using a sharp pointed instrument like a scriber under the clip part...
bill hughes
Re: Xantia 2.0 hdi
Thanks for the tip Jim, I haven't removed the offending pipe yet but when I do I am going to have it framed, 54 euros for a relatively short piece of rubber return tube.
- x 8458
Re: Xantia 2.0 hdi
They use a random number generator to determine pricing Bill
bill hughes
