synergie 2.0 hdi cooling fan
waveyr02
Unread post by waveyr02 »
Hello All, I wonder if anyone could tell me at what temperature the cooling fan should come on, I was in traffic today and saw 95 degrees on temp gauge but no fan on, I just wondered if I need to investigate this.
Thanks Simon.
ken newbold
x 4
Re: synergie 2.0 hdi cooling fan
Unread post by ken newbold »
Think they normallly come in at 83 & 90. You're temp gauge might not be so acturate, but maybe your fan control sensor is knacked.
1998 1.9td Peugeot 806 (Red shed 2)
2004 Citroen C3 1.4HDi
2003 2.2 Pug 807, Gone and never again!
x 1924
Unread post by Paul-R »
Or the fuse (possibly a maxifuse) could be blown. The fan could have seized after a winter of disuse - this can also then blow the fuse.
waveyr02
Thanks for replies, checked fuses all ok, fan free to turn, so I disconnected fan and put 12v to each terminal, seems that low speed isn't working, wonder if there is a resistor in the fan assembly that might be gone, read somewhere that high speed woundnt come on til 100 degrees which I didn't get to. By control unit I imagine that is a black box somewhere rather than a switch in the rad.
Thanks Simon.
