My C5 Estate 2004 - 2008 Front brake pads need replacing
has anyone used a good upgrade from the normal Valeo stuff or found even better ?
C5 2004 - 2008 Front brake pads
lakanooky2
Thanks In Advance Mark
1999 Xantia 2.0 HDI SX Blue ...... Scrapyard in the sky
2003 C5 2.0 8v HDI VTR Green with Leather
2004 C5 2.0 8V HDI Exclusive Estate Red with Leather
2004 C5 2.0 16v HDI VTR Hatchback Red
2005 C5 2.0 16V HDI VTR Estate Black with Leather
lakanooky2
Re: C5 2004 - 2008 Front brake pads
Has everyone used the Citroen pads ?
Or found better ?
Or found better ?
lakanooky2
Anyone used the green or red stuff pads ?
- x 6945
I use genuine Citroen pads, never have any issues, squeaks and they do the job. Red / Green? Not sure what you mean, but whatever you choose make sure they fully fit the disc or you'll get the lip effect and will likely have to replace the disc too at the next change.
zs&tas
- x 16
I needed discs so bought upgraded discs and softer than citroens pads. As citroen want the c5 discs to wear quick and replace often. That costs . So now I just change pads. Much cheaper.
- x 6945
Which Brand / Type of Discs did you use then?zs&tas wrote:I needed discs so bought upgraded discs and softer than citroens pads. As citroen want the c5 discs to wear quick and replace often. That costs . So now I just change pads. Much cheaper.
zs&tas
- x 16
Think I went with mtec. And there alright, there was a big difference in bite with them. Its important to not use the citroen pads though or any aftermarket long lasting pads. Greenstuff are good from what I hear although I did just pick up cheap pads from my local parts place.
