Help fitting inner track rod near side
BAZ-HDI
Hellp guys, just want to know what's the best way on going about fitting a inner track rod on near side, the car in question is a CITROEN picasso 2.0 HDI 2005, thanks for help in advance
jimmymarsbar
- x 13
Re: Help fitting inner track rod near side
Haynes manual tells you to use a specialist tool to remove the rod from the rack, and generic tools are available from Machine Mart and eBay etc.
However, I've heard that a pipe wrench can be use just as efficiently.
BAZ-HDI
I see I don't have a haynes manual, but is it easy enough to remove
van ordinaire
- (Donor 2017)
- x 402
When I did mine on the C15 (& from what's been writ they're all much of a muchness) I used a small pair of Stilsons. From memory, it's only the 1st 1/2-turn that's tricky, after that it disengages & just winds out.jimmymarsbar wrote:Haynes manual tells you to use a specialist tool to remove the rod from the rack, and generic tools are available from Machine Mart and eBay etc.
Citroens:-
'81 2CV Club
'05 C15
'97 Xantia Exclusive estate
others:-
Jeep XJ Cherokees x 3
'96 Cadillac Eldorado
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
