Help fitting inner track rod near side
BAZ-HDI
Unread post by BAZ-HDI »
Hellp guys, just want to know what's the best way on going about fitting a inner track rod on near side, the car in question is a CITROEN picasso 2.0 HDI 2005, thanks for help in advance
jimmymarsbar
x 13
Re: Help fitting inner track rod near side
Unread post by jimmymarsbar »
Haynes manual tells you to use a specialist tool to remove the rod from the rack, and generic tools are available from Machine Mart and eBay etc.
However, I've heard that a pipe wrench can be use just as efficiently.
BAZ-HDI
I see I don't have a haynes manual, but is it easy enough to remove
van ordinaire
(Donor 2017)
x 400
jimmymarsbar wrote:Haynes manual tells you to use a specialist tool to remove the rod from the rack, and generic tools are available from Machine Mart and eBay etc.
When I did mine on the C15 (& from what's been writ they're all much of a muchness) I used a small pair of Stilsons. From memory, it's only the 1st 1/2-turn that's tricky, after that it disengages & just winds out.
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
